Alpha one ID
yam 3
My serial number is OC846990. From what I gather it is a gen II. Looking for some confirmation before I order an impeller. I would like to get the complete kit, with wear plate cage etc. Which one is it?
yam 3
Re: Alpha one ID
I am confused myself, but i believe it has the "swept" skeg. I ordered a gen II complete kit from boatfix.com part # SIE183147.
Anything else i will need besides basic hand tools/lube? I plan on just removing the lower unit vs. the entire drive.
I am a first timer, but I'm good with mechanical things.
Fun Times
Re: Alpha one ID
Your sterndrive is a 1989 MERCRUISER ALPHA ONE STERNDRIVE.
You will want to use service manual #6 R/MR/ALPHA ONE.
47-89984T5 IMPELLER KIT, Water Pump
46-96148T1 WATER PUMP BODY ASSEMBLY
Here are your parts.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=99964
yam 3
Re: Alpha one ID
argggh. You are correct sir it is an 89 model alpha and not a Gen II.
So how about it...can I do this in a day with normal hand tools. Anything I need other than the kit like gaskets and sealants?
