Alpha One Trim Motor Pump Issue
Lubeboy
Okay... We have said outdrive, the trim moves very slow up and down. I tired to hot wire the pump by connecting hot wire directly to up and down wires on pump motor (it is three wire)... it does the same thing, so assuming the solenoids good... We took pump off boat, does same thing with another battery...
Here is trick... We took motor off the pump and hooked up to battery, it runs real fast...... hooked back up to pump and same slow movement...
By the way, the wires also get real hot when we hot wire...
Is motor bad, or pump, or both? What else can we check?
thanks as always.
CheapboatKev
Re: Alpha One Trim Motor Pump Issue
"said" outdrive? ;)
Dont know that model...Please post what exactly we are looking at..
Lubeboy
yeah, sorry...
We have a 1987 MerCruiser, with 5.7L 260HP V-8
We are trying to figure out what wrong with trim hydraulic motor/pump
CheapboatKev
Well..You do say Alpha One in the subject..I'll give you that.
Do you have the OEM manual? If not you know you can download it at the front page on the top of this forum.
Lubeboy
Yes thanks, I have manual, and have run through a pretty good troubleshooting effort... I am just at a point where MOTOR mechanics come in... I am trying to determine if I should try a new motor or new motor and pump.
thanks.
Ayuh,... It Sounds like the Pump, but still Could be the motor...
I'd just buy 1 of the New Style from SEI/ iboats,... It's plug & play....
ENSIGN
Take a look inside the motor,If there's any rust or water it's time for a rebuild.
betayv
if you need just the motor try ebay is couple of brand new for a good price if you need the complete pump, get it from SEI good price for a complete pump.
jchapp
Did you find solution to your trim problem? I have similar problem with wires heating when jumping hot directly to motor lead.
bigdan1
I have same problem with a 3.0L outdrive ...on mine it is the wires coming out of the outdrive in the engine bay that are rot !
noticed this when took the engine out for a refresh !
are they similar ?
BAproject
Bad ground?
low fluid.....
