Alpha to Bravo
degree
Does anyone know how much trouble this conversion is? I'm told the bolt pattern is the same, so I'll not have trouble there, but can I use the (Alpha) inner transom plate? They look the same in photos...
Re: Alpha to Bravo
Nope, it's different too.
Re: Alpha to Bravo
Ayuh,......
Everything aft of the rear motor mounts has to be Changed,.....
As well as several things mounted to the Motor itself........
