Alpha Trim Switch open up under heavy load // but works great otherwise.
wellcraft-classic210
Just wondering if anyone has seen this before.
The Vessel= an 1983 Searay 260DA with a 260 Merc ( 350 - Alpha -1 )
The problem = The Trim Switch open up under load ( when on plane -consistently) // but works great otherwise (slower speeds etc ).
Its been very repeatable and consistent for over 50 hours of operation.
The trailer switch always works ( even when on plane ) and placing a jumper in place of the trim switch will allow that to work also. ( with no limit of coarse )
Its been doing it since I got the boat running last year. I replaced the bellows & a lot of related components ( including the trim switch ) to make it seaworthy.
Its on the water now // When I do pull it out -- I will look for any excessive Gimbal bolt & housing movement ( side to side ETC. ) and may try to re-position or replacing the switch as well.
Any advice is welcome -- Especially on specs & shimming the drive to reduce side to side movement.
Thanks!!!
Bt Doctur
Bad limit switch or wiring
Nope. steering arm or steering pin worn
