Alpha2 Gen2 sterndrive gimble housing
Stranglehold
516C6214-16C0-4577-9482-1BAE92AA60A3.jpegWould anyone know what this hole is? It’s behind the oil seal and humble bearing. We’re changing our bellows.
Any info much appreciated!
Bt Doctur
like the round hole above the bearing it is another vent, lets you see water entering the boat from the bellow
Stranglehold
Why would we want to see water entering the boat? Isn’t the bellows supposed to prevent that? Sorry, I’m not the most mechanical. Husband is doing the work. He’s a millwright, but I’m better at finding information in line. Thank you!
Ayuh,..... Welcome Aboard,.... You don't wanta see water comin' in,....
But if the bellows is holed, it will come in, tellin' ya to fix yer boat,....
Stinnett21
Gotta admit I'm lost on this one. Do you mean the hole (at least the bottom one) lets water escape if the bellows is leaking? So if water is allowed to escape via this hole it would be viewable from inside the boat? Am I on the right track? The round hole above is only to vent?
