alternator starts charging after 2500 rpm's not before ? please help i am stumped
osborne looney
2001 m/craft 5.7L weirdest thing i have come across yet !!! alt will NOT charge till after 2500 rpm's then it seems to be charging all the way down to idle -- until i shut it down -- then it starts all over again -- YES NEW LEESE NEVILLE ALT !!!! i am baffled -- stumped all wiring is good as well .NEW battery as well
Is it a one wire alt or standard?
Do you have more then one battery? If so is there a battery switch, isolator or ACR?
osborne looney
standard 3 wire positive ground and exciter one battery no batt switch isolator either
Will agree they need to bring up the rpm the first time to start working but normally its in the 1500 range, going to 2500 is different from what I normally see. Could also be your tach is a bit off. Don't know which model engine you have but have you check the voltage output, is it 14.5V during charging and is the battery at 100% ?
osborne looney
14.3 at full charge with 100% 12.6 volt on new battery -- i guess i will just have to rev it before taking off every time i start it -- thanks all
