Alumacraft one-piece hull
a_tack
Does alumacraft use their one-piece hull design even on their rivited jons? Also, what are your thoughts on the 1436LT from Alumacraft? It seems to have much thicker aluminum compared to ther branded Light models. Thanks in advance for the info.
Re: Alumacraft one-piece hull
Yes. Even the riveted hulls use a one piece bottom in just about all brands. The 1436 is a lightweight Jon and yes about 1/100th of an inch thicker then others.......... they will all last about the same length of time if cared for.
