aluminum bushings at rear engine mounts v6
gixxerjim
I am installing a V6 mercruiser engine. The rear mounts have aluminum bushings. Do these go under the washer under the bolt head or between the motor and rear motor mount?
Does anyone have a diagram of this mount?
Thanks for the help
Bt Doctur
starting with the bolt, then the washer, then the bushing, then inserted into the housing, thru the double wound spring ,and into the nut.
