Aluminum exhausts manifold?
Eddie Ray
Aq125q. 270OD. 1985 trophy
Dose anyone make an aluminum manifold for this boat?it seems that it would be better than the steel one.
Just wondering?
Eddie
Re: Aluminum exhausts manifold?
since your in Naples, going to assume salt water. Aluminum exhaust is not recommended for salt water unless you have a full closed cooling system.
In Salt, you just have to change your manifolds every 3-5 years.
ewenm
that would assume that the boat is moored if its trailered and flushed after every use it would be ok surly???/
also lucky you, here in australia manifolds and risers is a $2000.00 (V6 or V8) plus job and then add labour
so you really want to get as much life out of them as you can
