aluminum prop comparison
MBAKER
Between different manufacturers do most props of a given size/pitch act the same or are some better than others? Do certain manufacturers have things they prioritize over others? I am looking at changing pitch and have run the following in no certain order just what happened to be available but if I change pitch I want to know what I am comparing and/or stay within a given manufacturer etc. I am currently running a 18P but with lighter loads than in the past and feel under propped now and easily run to 4800 with throttle to spare. (20' open bow 5.7 alpha 1) It is 4 blade for the low end pulling but not against going back to 3 either. Trying to decide about bumping to 19 or 20 pitch 4 blade, or 19 or 21 pitch 3 blade but if different props act differently I want to take that into account.
Michigan?
Powertech?
BS Pro?
Mercury?
All your numbers mean nothing without knowing the max rpm rating on your motor and the current max rpm of each different prop at wot. Numbers need to be accurate, not estimates. Even before that, is the engine running at its peak ? Mounted the right height and properly trimmed to get the correct readings.??
Stinnett21
Even within the same manufacturer when you switch prop families, e.g Mercury Vengeance to Mercury Tempest Plus, you cannot count on them acting the same. I've not experienced this but some report that that two, what appear to be identical props, taken right out of the box will often not run the same. It is best to find a prop retailer that will work with you on letting you try before you buy.
MBAKER
I guess I was just looking for general thoughts about different options or brands compared to each other and what other's experiences were with each more than anything. In my experiences with this same boat over the last 15 years the way we are running now it feels under propped on top because I have to hold back throttle more than I remembered but pulls well on bottom. Since we rarely ever run over 3500 for cruising anyway I may just leave it and not worry about it, I really could care less how fast it is on top.
Stinnett21
As a starting point put your info into the Mercury Prop Selector and see what it spits out.
Stinnett21
If you are not carrying as much weight as before and you are having to throttle back to not exceed operating range I would change to a 3 blade. I realize you are not interested in top end but efficiency is another factor.
MBAKER
I have run it through the prop selector before and end up anywhere from 15.5x18 black max, to 14.25x21. I am at 14.5x18 4 blade currently, have a 19 3 blade I can throw back on. One thing I remembered when we switched was the 4 blade did stay on plane 2-300 rpm slower which at times is nice. Interestingly I wonder if the 15.5 diamter 3 blade would be similar in blade area to the 4 blade at 14.5 considering the blade shape is slightly different from what I have seen. Possibly same blade area but one less blade to drag around.
We used to go out full of fuel, 4-5 adults plus kids, toys etc. Now I generally only carry 1/2 fuel, 3 adults and couple kids and half the toys. If we still loaded down what we have I'm sure would be fine. But am thinking 20 pitch 4 blade similar to what I have or 21 3 blade might be better for just cruising around.
If your engine is not capable of reaching its max wot rpm, then it is lugging down, using more fuel than necessary and putting excess load on the motor. Whether you run wot or not, having the proper pitch means your good thru all the rpm range, not just wot.
cyclops222
The driver is responsible for NOT OVER REVING the engine at any time.
If the Rev Limiter is not working. Or the engine does not have one.
BUT BUT
need to see what RPM you are turning at WOT with the throttle lever mashed
lugging a motor will not only kill it, it will burn more fuel.
see the first sticky in the prop forum. have the answers to those 6 questions.
MBAKER
Again, I was looking more for opinions on different prop lines/brands etc. and I understand about the revs, speed etc at WOT and wasn't looking for help that way. Any info I gave was just a general idea of where I stood with the current prop. If anyone had suggestions in 'general' that any one of those brands of props 'generally' perform better than others in my situation (idle to 3500) is all I was looking for.
As I also stated engine is definitely note being lugged, its your typical 5.7 mercruiser so top rpm is 44-4800 and I can run it to 4800 and still have an inch or more of throttle lever to go.
Then that would indicate you are under propped ( less pitch than needed) but....until we have exact numbers any recommendation would be just a guess. Serious boaters realize guesses cost us money in the long run..
MBAKER
That's what I have been saying all along, I am under propped for how I am now running this boat. I know which direction I need to go in pitch. The question was which prop maker may have general characteristics that may be beneficial over others. You are right though I am probably not that serious all things considered, just a middle age guy in the middle of the country enjoying a few hours at a time with the family.
I always had fairly good luck with Michigan and Mercury aluminum props, for what they are. Never used a powertech al prop, my brother has a stainless 4 blade PT on his twin vee power cat it works very well and would consider it a reasonably good quality prop.
The michigan Vortex props I have used are good quality for the price. I wouldnt overthink it as there is a big difference in performance (and price) bewteen any of the aluminum props and good stainless ones.
I have a similar size bowrider to you - I run a revolution 4 21" (SS) and get the same WOT RPM as a 23" Merc Spitfire 4 blade AL , there is that much a a slip difference on it. Really was disappointed with the claims on the spitfire vs actual real world performance.
Stinnett21
The Spitfire is Mercury's attempt at building a Rev 4 out of aluminum. So it doesn't surprise me the thicker aluminum 23 matches the 21 steel.
Stinnett21
Turning Point and Solas make decent props it's just that their quality control is not what you will find with homegrown Mercury or PowerTech products. At least that's what I gather after reading many many threads on this subject.
Stinnett21
MBAKER, in your original post you list BS Pro props. I had never heard of it. Appears to be a Korean aftermarket brand. Could be good to look into.
MBAKER
BS Pro is Baek San propeller, not sure if it was Korea or China. Actually they were making aluminum props for PowerTech for a while that’s how I ended up with a couple of them a few years ago. After talking to powertech this morning I was told they had switched to another supplier because of quality issues. That said I had good luck with them and never broke one, now how much technology is in them I don’t know. Again the way I understood powertech helped design their line but if it’s like most offshore stuff the molds probably got copied and I would assume the BS prop is the same as the old powertech. Don’t hold me to it but if I understood right BS was also making some props for Michigan and possibly Mercury.
