Aluminum Rivets
rterrian
Can anyone tell me where I can buy Aluminum Rivets online?
yankneck
Re: Aluminum Rivets
Not sure about online but I buy them at my local fasnter company. They usaly like a minimum order though.
Trent
Re: Aluminum Rivets
Your local airport should have them if you only need a few. What size and length?
Re: Aluminum Rivets
I got them at local hardware store.
downjigger
Re: Aluminum Rivets
McMaster-Carr on line they have about anything you can think of. Some prices good some a little high-great service and delivery.<br /><br />www.mcmaster.com
Silvertip
Re: Aluminum Rivets
Make sure you buy solid rivets. Simple pop rivets will leak. If you look at the rivets in your boat you will not see the tell-tale hole you see in a pop rivet. Solid rivets must be "bucked" to be installed properly.
