Is there a difference in hub design style, or material for the different prop via SS or alum ???
xcelr8z28 Seaman Apprentice Joined May 22, 2007 Messages 49 Mar 8, 2009 #1 Is there a difference in hub design style, or material for the different prop via SS or alum ???
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,418 Mar 8, 2009 #2 Re: Aluminum Vs SS prop hubs Ayuh,... There's Lots of Styles of Props,+ their Hubs,... Both in Aluminum,+ in SSteel...
P propmann Cadet Joined Dec 30, 2008 Messages 13 Mar 8, 2009 #3 Re: Aluminum Vs SS prop hubs If you take a rubber hub type prop the stainless prop has a harder rubber than the aluminum rubber hub.
