ALWAYS Check Your Oil...
steddy
...BEFORE you run your engine. For any length of time. No matter what.
Last time out boating, I noticed just the smallest puddle of oil on the floor of the bilge before launching. I attributed it to the breather that likes to come off the top of my 3.0 MerCruiser by the air filter and drip some oil from there. Dried it up, pulled the dipstick found the level right where it should be, and went on my way. Ran the boat for maybe 45 minutes that day - short trip out to the Lake Michigan, chill for the day, motor back to the launch.
That was just over a month ago. Today, I went to winterize it. Since the boat is for sale, I wanted to make sure I did things right (as always) so as to not have any suprises in the Spring. I planned on putting in the Sta-Bil, replacing the spark plugs, warming up the engine for a few minutes, fogging, changing oil, and winterizing the block. On went the muffs, then crank the engine. No oil checking this time. "Eh, it's just going to run for 10 minutes. Why bother?" It took some cranking, since the engine hasn't been run in a month. Probably a good thing that it did. Engine started, and I anxiously awaited with my hand on the ignition for the oil gauge to show some pressure, which it did after about 2 or 3 seconds of running. It fluttered a little after about 10 seconds of 1300 RPM, but it didn't dawn on me that there might be a problem for another minute or two.
Hmmmmmmmm.......
Figured it was because I fouled a plug while cranking, so it wasn't running real well. No problem, brand new plugs in my hand. Remove doghouse cover to change them. Nearly pass out. ALMOST A QUART OF OIL IN THE BILGE!!!!!!!!!!! WHAT THE #$@!^&$#$%#$#$^%??????!!!!!!!!
Turns out the oil filter loosened up. It was that simple. Now I decide check the oil. Level is just over half way between the end of the stick and the "ADD" line. I convinced myself that everything was OK, since there was so much oil on the stick, I had oil pressure the whole time, and it didn't run that long. I also figured most of the oil was there just from dripping out while in storage. It was pretty well pooled, not sprayed everywhere.
The moral of the story: If I had checked the oil before cranking it up, I would have seen the mass of oil down in the bilge and figured it out before anything. I sure am glad I didn't run it any longer last time out... the filter could have loosened up even more, thus losing all oil pressure. It for sure would have been good-bye engine.
Re: ALWAYS Check Your Oil...
Ayuh,... Every mornin' for me,....Part of the daily Safety Check.....;)
JustJason
Agreed... and thats why they put that check in both the owners and service manuals...
The problem with boats, especially ones that sit in the water. Is that some boats sitting are bow heavy. If you have a leak you might not even see it if you always have just a little water in the bilge that the oil floats on because it all runs to the front of the boat.
This brings to mind something we came across this past summer. We had ordered several oil filters of the same make and number to have on hand. After doing an oil and filter change on a boat, using one of the new stock filters, we took a run in the boat. Oil pressure was initially solid; however, shortly we noticed a fast drop in pressure and shut down. We found that the oil was running out between the filter and the block, as if the seal was missing, but upon removing the filter, found the seal present. After a tow back to the dock, we looked at the filter again and found that the specific model number on the box (the correct number) did not match the number printed on the filter.
After doing some research, we found that both the correct and incorrect filters were the same length and diameter; however, the seal itself on the incorrect filter was actually slightly smaller in diameter than the correct filter, thus allowing the oil to flow outside the oil returns. After checking our stock, this was the only incorrect filter we had, but we now make it a point to not rely just on the packaging information and always compare intended part numbers with those actually printer/stamped on the part itself as we do the install.
