Am I missing a step in gear lube swap?
lrdchaos
Going to swap out me gear lube on my b3 outdrive.
So I’m going to take off the cap on the reservoir on the engine, pull the vent(upper) plug, pull the lower plug and make sure the drive is down.
Once it all drains, I will start pumping 90w high performance gear lube from the bottom hole until it runs out of the upper hole on the drive, put the plug back in and keep pumping until it backfills the reservoir. Once the reservoir is full, unscrew the pump tube and replace the bottom screw.
Did I miss anything? I also plan on replacing the plug gaskets.
you need a beer to two to drink while pumping the lube in ...other than that you have it down
nola mike
Wow, do you have one of those hats with the straws? BTW, while filling the gear lube the other day, I finally counted the number of pumps it took: 350. You're welcome.
besides the beer or three, you may have to switch hands doing the pumping.
ImTheBiggerBoat
I'd like to jump in here for a minute if that's ok since the OP got his answer. I have an alpha 1 gen 2, just de-winterized the boat, performed all steps listed above...except, once the lube started coming out of the vent hole I screwed all plugs back in annddddd...ran the boat for about 15 minutes, 2 or 3 of those minutes at WOT. I completely forgot to pump to the reservoir. What are my chances here, just re-pump from the bottom until it's to the full line or have I possibly done serious damage to the lower unit?
nola mike
In general, start your own thread. But you're fine.
Yes you are ok because drive was full covering the upper gear set. Yiu can refill reservoir as the air will work its way out. Issue is the level alarm should have gone off giving you the warning beep that should come on briefly when you start the engine , should have been constant…
ImTheBiggerBoat
No alarm on this dinosaur, Thanks for the info, I wasn't sure if 100% submersion was achievable by reaching the vent hole. I'll continue to fill. Again, thanks
could be look on the bottom of your lube reservoir if there are two wires connected to the harness it should have an alarm.
Drcoffee
I assume the alarm only sounds when the resevior is low, not the drive unit. It may take some time for the oil to migrate down to the drive befoe the alarm is activated. My guess is as long as the oil came out the upper hole you should be golden.
That's correct only when reservoir is low or empty, drive would still be full. Nice design vs the gen I where if your input shaft seal goes you fill the bellows with oil and your upper runs dry...
