Another dumb question, what is the difference between Johnson and Evinrude motors?
gjmsd
What is the difference between Johnson and Evinrude motors? I have one of each and can't see any difference. The parts are interchangeable as far as I can tell.
Daviet
Re: Another dumb question, what is the difference between Johnson and Evinrude motors
Paint color and decals.
Joe Reeves
Yep, what Daviet said.
JDusza
$0.07
coolbri70
if you go with the johnson you get to say " i got a big johnson ":D
gjmsd
But on my speedboat, I get to say "I got Rude Motor"
The real truth is... After final assembly of the powerhead, the engines were test run and dyno tested. Those which started easily and had better than average horsepower on the dyno were painted Evinrude Colours and the rest were painted Johnson Colours. ;)
mark1961
Ensign
All the faultless motors got the Evinrude paint job and decals :cool:.....and ahh well, you know the rest. :eek::D
seahorse5
14 years ago, Johnson and Evinrude split and were never the same motors after that year. Evinrude became the high-tech low-emission engine, and Johnson - until its demise in 2006 - was the carbureted traditional motor and, after Bombardier took over, it had the 4 stroke Suzuki models also.
Prior to '98 and for some years before that, then they were basically the same.
