Another one...Upholstery
JDA1975
took a day to work on my other pontoon, let the guy see the work is in progress and the quality of it, so he can have some peace of mind while waiting...so I took on what I consider the hardest part of the job, redoing the captains chair
Started by removing the vinyl and ripping key seams to get my patterns for new covers
then put it back together
The wrap around of the back/sides I marked with letter to make it easier to put back together, then ripped the seams and traced the patterns
then started putting them back together
So this thread is where I will post progress on this job, more to follow
Woodonglass
Re: Another one...Upholstery
It "Seams" the "Slant 66" is purring like a Kitten!!!:D
JDA1975
not sure what this slant 66 you speak of is...but my slant-o-matic 500A is running great...I think the problem was just a dull needle like ya said....funny how I used to break them before they ever needed to be changed, and now I never break needles, and apparently forget to replace them
Woodonglass
Singer 503A Slant-O-Matic
Manufactured: 1961, Anderson, South Carolina
Serial Number: NC651857
Needle: Standard 15x1
Bobbins: Singer Class 66
Mechanism type: Rotary round bobbin
Feed: can be lowered (throat plate is raised)
Feet: slant shank
It uses a Class66 Bobbin and some of the old timers called em a Slant 66
This PDF File on sewing upholstery with a Home Sewing machine might be of interest...
(Double Click to open PDF)
View attachment Using+A+Home+Machine+for+Sail+And+Canvas+Work[1].pdf
JDA1975
aha.....lol call it what ya want just dont call it broken!
JDA1975
Got the hardest part done...wrapping those bucket captains chairs is some tricky sewing...I think it came out OK though...
Ciera2450
Looks great judge!
May I ask what type of foam you are using? Building some seating of my own and the price of the EZ-dri foam nearly made me soil myself.
JDA1975
I am reusing the foam that original seats had, but check out wood on glasses thread, or the upholstery section of my skeeter thread and he used couch donor foam, I also used donor foam per customer request on the pontoon seats, but I will never do that again...the amount of work involved in cutting foam down to proper thickness isn't worth if they need new foam, they will need to buy new foam lol
JDA1975
Done, and did. now on to the benches, it is all straight lines so should move fast on this one!
jbcurt00
Looks like the help is laying down on the job... Seat looks great, benches from here on should be a breeze compared to that bucket....
74bayliner
hey judge looks great bud... What i really wanna do is visit the Veada factory and watch them work for a couple of hours! i am sure alot of information could be learned just from watching. But alas... they wont let people do that... that would be like Ivars posting their clam chowder recipe online for all to see :( Keep at it , soon enough fellow iboaters will be sending thier orders to u :p
Woodonglass
Hurry Up! Slacker! Oh wait, that's the DOG!!!
Nice work Judge!!!
Ciera2450
That bucket seat looks excellent! Well done sir!
JDA1975
Had to make flaps that cover some cubby holes and snap closed
Started by cutting them to size...my width finished needed to be 6" so I cut them 8", finished length needed to be 12.5" so cut them 13.5". Then I marked them out at 1" in and 2" in.
Set the seam guide on my machine at 3/4" from needle and sewed them face down, holding my edge to the 2" mark
Then I set my seam guide a 1/4" and sewed the next stitch..then installed my buttons
this job was actually quite time consuming, took me roughly 4 hours start to finish...of course I take a break about every 30 mins for 10 so probably about 3 hours working time
JDA1975
So I took the buttoned flaps and sewed those to the front pieces, the combined the front and top pieces together
giving me a finished top and front
then took those and combined with a piece that ran all the way around the base by sewing it along the front then following the top and coming back down the front on the other side...giving me a perfect slip cover
will cut out the access hole and drink holder after all is stapled in
Woodonglass
For an Ark-EE-Saw boy and a Old Time Sewing Machine, I'd say that's sum rite good sewin!!!!!
JDA1975
luckily they all were the same size..I only measured one and made them all like that...yay they fit
craigweaver
Judge, what I think I like the most on your upholstry threads is the level of detail you put into explaining how you did it. It's like a 101 guide for us newbs :) Keep up the great work!
JDA1975
I am just tired so short and sweet...bases...nuf said! these bases were simple, cut my vinyl 18" X 144" long and wrap around it in one piece. Did not like the old hinge system so added a 1X2 to the front edge so I could install piano hinges as well
jbcurt00
Proceeding nicely! Looks great.....
