Another steering question.
gener8s
Hi everyone,
I have a 2004 Bayliner 185 with a 3.0L and an Alpha 1 gen 2 outdrive, equipt with non-power rack and pinion steering. The steering has been stiff ever since I bought the boat 3 years ago. It's not to bad on plane once I set my trim, but at lower speeds it's pretty bad (makes my dash creak everytime I turn the wheel!). I have removed the cable and can move the drive back and forth without any serious effort, and the helm moves freely but does seem a little stiff (I can move the cable back and forth off the boat, but once coupled with the helm, forget it). From the part number I can tell that it isn't a NFB helm. I am going to replace everything and am wondering which avenue I should follow. Hydraulic, rotary, or another rack? The admiral refuses to drive the boat and I would like to make it easier to steer.
Thx!
Re: Another steering question.
Hi everyone,
Thx!
Ayuh,.... Welcome Aboard,.... Did ya clean 'n regrease the Inside of the aluminum tube at the transom,..??
gener8s
Thanks for the reply! Yep, the tube was pretty clean so I gave it a wipe and applied a liberal coating of 2-4-C. How stiff should the steering/cable be?
SeaRayboater95
I had the same problem with mine. I could hardly get the wheel to turn even when not attached to the steering arm. I replaced the NFB teleflex steering cable and it was one finger steering after that. I have a v-eight and powersteering, but even with powersteering it was two handed steering....
Ken
