another stringer question
proshine43
Hello to all. Im about to install my stringers using pl premium. But when i dry fit them in place i nitice the ends of the stringers are touching but theres about a 1/2" gap in the middle. Is this ok or is my hull distorted? I have the cap sitting on the hull now and it seems perfect. The stringers arent warped. I know that no part of the stringers will touch the hull once the pl is applied, but i just wanted to double check. Thanks.
Cadwelder
Re: another stringer question
How long is the gap? Is it only on one stringer or both sides?
Most stringer's are NOT straight and have to be custom made/cut ..... ????
Friscoboater
I do not think that will be an issue. I have some gaps in mine too and was going to mix up some peanut butter to fill it.
proshine43
Hello. My gaps are about 3-4 feet, and its both stringers.
