Any clues to what these are?
JP_R
Hi All..... Long shot but trying to find out what these are before I rip them out. They look to be the base for liquid dispensers but I have not be able to find anything by searching marine / boat liquid dispenser.
Boat is a 2004 Four Winns (not a factory install or option)
If they don't go thru the counter then who knows what the PO had there
gm280
Honestly have no idea. But with the little hook-like inside areas, seems whatever they go on, clips on over a recessed groove/lip and made be hard to remove again... JMHO
jhande
Taking a shot in the dark here but they could be bases for some kind of liquid soap dispensers.
JP_R
Yeah my best guess was for soap and conditioner.
There is also one on cockpit sink. Given the bases are already glued, I was wanting to find the right dispensers. At this point it looks like I am ripping them off.
JP_R
I'm thinking the same thing. Add RV accessories to your searching.
Great suggestion on adding RV to the search.... THANK YOU!
I found what they are on an RV forum.. looks like they will be hard to find though. Currently unavailable...
GA_Boater
If you can find the empty bottles in the boat, they might be refillable.
JimS123
You might just be right. But why would anyone put that stuff in a freaking boat?
