Any info on Chrysler Marine 80?
69seabreeze
Well I got the 52 dollar ebay boat home and, after giving it a quick going over, decided that I will try to see if the engine will start. However, I need a little info on the engine. It says chrysler marine 80 on the engine data plate, and 1500 on the head. It's the I/O, and the stern drive is also a chrysler unit. Any info regarding where to find parts, or an online repair manual, or junkyards around chicago that have boat parts would be greatly appreciated. So far it needs spark plugs, wires, and a battery. Should probably pull the whole thing apart, but who has time for that stuff ;).
Re: Any info on Chrysler Marine 80?
Post some pictures.
Ayuh,....
I guess you didn't like My Opinion in your other thread....
Marysville Marine, in Marysville Mich. is the Only place in the world that just Might, Possibly have parts for that thing.....
Donate it to a Museum,.... Maybe you can get a Tax Credit for it.... :rolleyes:
Btw,...
Don, He had a link to the ebay auction on his other thread...
69seabreeze
Yup, I don't give up that easily. Found spark plugs for it today at Autozone. Just cross referenced my part number. Gonna pull the engine apart over the next week and see what I'm really dealing with.
Ayuh,....
Have Fun with it,+ keep Us posted,....
Maybe We'll start a pool on how much it'll cost to actually Use the boat,....
I'm thinking $1520.00 will be Much too Low..... $5200.00 Maybe,..?? :D
Good Luck.....
69seabreeze
As long as I get half the pool for my services when its over then game on!
69seabreeze
Little update-found an original manual on ebay for $8. You can add that to the $4 for spark plugs and you have a $12 total so far.
Ayuh,... :D :D
Sure Glad you've got a Great sense of Humor....
$52.00
$ 8.00
$ 4.00
Ayuh,... That's $64.00...
69seabreeze
Didn't know we were adding the original $52 also. I guess that puts you a little farther ahead
I just looked at The Pictures. DUDE!, you ain't got no exhaust manifold on that engine, or alternator, or wiring or lots of other obvious parts. There are no spark plugs in it now. My guess is the engine is locked solid from rust. The manifold is going to be an NLA part for sure, and used are about as good as what you already have. Who knows what the drive has in store for you. Your best hope would be to get that engine (using the term very loosly) and outddrive off the boat, fix the transom, I would bet it's dryrotted, then put a different engine and outdrive combination in it.
69seabreeze
Joke will be on all of you when I'm out on the water with my 69 marine 80.
Let's put it this way, posting to say you have spent 4 bucks for spark plugs and 8 bucks for a manual is a waste of time and means nothing if the engine won't turn over because it's rusted into one piece, and you can't get parts to fix it.
JustJason
Trust us...... NO...... No you won't be..... not in that junker.
You essentially paid 52 bucks for something that should have cost the original owner a few hundered to dispose of.
Here's what i'd do with that thing.....
1rst.... pull the winshield, motor and drive. Remove all the electrical and the fuel tank
2nd.... get your favorite sawzall and slice the thing right down the middle.... from stem to stern.
3rd.... Remove all the wood and all the junk...... give the inside of it a light sand and then spray it all down with rubberized undercoating.
4th..... if you got the room in your basement.... bolt the 2 halves of the transom together. Pay special attention to try and get the seams to match (they won't though, not on a boat that old, but still do your best, you should be able to bondo match the seam with some sucess)
5th..... build a frame so the thing will stand upright and won't fall over.
6th..... on the inside of it..... build some shelves.... 2 or 3.... whatever fits well.
7th..... on top get some plywood and cut it to fit over the entire thing. Stain with your favorite color. use some select pine trimming to trim out the edges so you don't see the ply. Apply many many coats of polyurethane, varnish... or whatever floats your........ hehe... boat.
8...... reattach the winshield
9.......... get some nautical stuff.... a few lobster buoys.... a ships wheel.... maybe some old rope and decorate the outside of it. Nothing to crazy.... most of it can probably be had at peir 1 imports or christmastree shops for cheap.
10........ get come brass piping and make a border around the bottom of the boat...... about 1 foot off the ground.
11....... add a sink and some cool christmass lights!!!! The ones that dance are neat-o!!!
12....... Get some stools..... You know have the worlds first BOATBAR in your basement!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
13.... If your really lucky you may be able to get 10 bucks in scrap for steel on the engine block.... and 20 bucks in scrap aluminum for the drive and transom plates. Wooohoooo!!!!!! think of all the wood you could buy for the BOATBAR with 30 FREE BUCKS!!!!
14...... Ya have to admit.... a boatbar would be pretty freakin cool in your basement!!!!!
7th.....
CheapboatKev
ADDITIONAL FEES:
Transaction Fee: $75 for US Buyers
Need to add the "fine Print" charges to the running total.
My 200.00 boat has cost me that 2xs on starter, battery & beer...
I guess I have to change my name on here and hand it over...
(for a small transaction fee, of course).
Yank the anchor that is called a motor, remove the OD, patch the hole and get a OB hung....
Seriously, best of luck to ya
krisnowicki
good news is this may be one of the better investments found right now....
