Any special considerations on removing ECM
andrewterri
I need to remove the ecm for a 2014 4.3 MPI to get access to the dizzy cap and rotor to change them. Just remove power and unhook all connections? Will the boat run rough when everything is hooked back up like a car until it relearns everything?
achris
More fish than mountain goat
Yes. And 'ground' yourself before you remove the unit, don't touch any pins.
No.
Chris.......
just dont wear wool and be petting your cat when you pull the ECM and all will be good.
