Anyone got any dynamite
The lawn ranger
Ive got a 97 Mercury 150 XR2 no fire I've install new switch boxes new stator new trigger new plugs new regulator rectifier kill circuit checks out dva checks out, compression checked, checked wiring no spark very frustrating, all i need now is some dynamite, anyone got any suggestions besides a new motor and mechanic?
With all that new stuff, maybe old wiring is bad? You did connect the banded stator and trigger wires to the same switchbox?
The lawn ranger
Sorry the problem was in the kill circuit, i ran a new wire from The nation to straight to the switch box es, now have fire, But I have ran into a new problem while doing the timing, it's flashing halfway around from zero way off scale, haven't figured out what I have done wrong yet
Sounds like you have the wrong wire from the switchbox, on the #1 coil, or the wrong trigger wire firing the #1 coil. You might recheck all the wiring.
The maxrules web site may have a wiring diagram for you.
