Anyone know?
Can I replace an Alpha 1 Gen 1 out drive with a Merc 120 outdrive?
Gear ratios are the same and both drives are right rotation.
Bt Doctur
Re: Anyone know?
If the gear ratios are the same, and the input shaft is the same, then Yes.
Either drive mounting gasket will work
