Anyone used plywood alternatives with a deck/stringer rebuild?
archbuilder
So I'll give my 2 cents worth.....
The answer is the same to this question as it is to the poly vs epoxy issue or the gel-coat vs marine paint vs automotive paint vs rustoleum conversations, whatever works best to fit your goals, project, how you use the boat and where you are, fresh water or seawater. Cost, time, and expectations all figure in there too, we all value them differently.
There is nothing wrong with a good grade of plywood or wood. It has to be carefully installed, and penetrations need to be carefully sealed. It is by far the cheapest, and materials are readily available most anywhere. Some grades, such as marine,maybe hard to find in your location, but a lot of people on here use lesser grades with great success. And I bet most manufacturers do as well. The down side is that it will evenetually rot, when that occurs is a function of how well it was installed and maintenance. Maintenance falls into two categories, storing the boat in a clean dry environment, and taking care anytime you put screws or bolts through the fiberglass into the wood. Once water gets in the rot starts. Well installed and maintained wood will last for years.
I'm supprised that you can still find the CCA (cromated copper arsenic) treated plywood. I figured the EPA eliminated it, they are very good at outlawing anything that actually works.....I thought you could only get CCA lumber in large members for direct burial and wharf applications. Bonding isn't an issue as long as it is dry and clean. The engineered wood columns in my barn are laminated CCA lumber, excellent product. I haven't seen or used it in a boat, but it sounds like a good step up from untreated wood.
I used seacast on Miss Morgan, and I am very happy with it. I don't plan on selling her, so long term, no maintenance was important to me. Its also solid as a rock, and I can drill holes into it without worrying about wet wood. ( I still take care to seal any penetrations)
I'm glad that Wood posted the link to Mick's thread, he did a lot better job of documenting it than I did.v (and he did great work in an old, cold barn in the middle of the Pennsylvania winter!) I installed my seacast a little bit before he started the rebuilding part of his build. He called me several times and ask me questions about the process and results. I thought he was going to go with wood because of the cost, but changed back to seacast. It was a really bad time in the economy and he called them up and got a good deal. Otherwise, I think he would have went the plywood route. I don't think those deals are around anymore, lol!
I still question the "cost" of seacast. Everyone looks at the plywood cost vs the seacast cost, raw material only. Which is a big number, but I didn't have to make any peanut butter for fillets or spend the time messing around with them. I layed up my "inner skin" (transom) on a table, cut it to shape (used a cardboard template), tabbed it in, and poured it full of seacast. I did that for both the stringer and the transom. The seacast essentially took the place of the peanut butter as well as the plywood. It flowed into every nook and cranny. I was worried about working time, but it was very forgiving even in the OK summer. Granted the raw material only cost isn't cheaper than wood, but it eliminates the peanut butter.....not sure what you guys spend on that. I'm sure the wood route is still cheaper when you look at the "whole product cost", but I bet the final numbers get a lot closer to each other.
Again, its just my preference, but its just a cleaner, simpler, more flexible process to me.
All that said, I have been back and forth on Fuggly. I started out with the idea of just doing her with wood, thinking I would eventually sell her anyhow. But the more time I spent doing demo and grinding, the more I thought "this sucks, I don't EVER want to do this again on this boat". Yes, I'm sure all you Tin guys will chime in, but the truth is demoing and grinding a glass boat flat out sucks!
I'm still up in the air on if I will keep the boat, we'll find out once she is on the water. But I have come to the conclusion she is going to be built with seacast. The deck is still going to be plywood....I haven't found a replacement for the deck that makes sense to me. But since the deck is the first thing you remove in a rebuilt, its also the easiest to remove and replace, which hopefully I never have to do....back to my wood instillation and maintenance theory.
I am planning on using the self leveling seacast on the bottoms of the sponsons and center pod to replace the 1/4" plywood. I'm pretty sure you can also use it to replace a deck, but it will run into some dollars. So I have ruled it out for this project, but maybe I will try it somewhere down the road.
In conclusion of my rambling, research the options, look at your situation and goals, then pick the route which works best for you!
Woodonglass
The other thing to consider in this debate is...NONE of the boats being restored on this forum had the stringers and transoms installed with the care and quatlity of materials that most of the members use when doing their restorations. And they were not cared for or maintained in the manner that the owner of a boat that he personally restored and suffered the misery of the "ITCH" to get her back on the water, will. Using good quality Fiberglassing techniques and following up with good care and maintenance will allow a WOOD Substructure to last for 50 years, IMHO!!! I think, for most of us, that means a LIFETIME. Thats long enuf for me!!! I'll use the money I save on the High Dollar materials to buy Fuel and spend more time on the lake.
archbuilder
Blah blah blah........and closed cell foam never gets water in it right? I seem to recall you saying that on here years ago.
jigngrub
How about Seacast transom and stringers and CCA decking? That would be pretty bad-azz eh?!
hadaveha
I got to say as sharp as so many of the guys here on this forum are, than someone hasn't come up with a DIY seacast formula yet.
Gyrene
You miss Scott's post??
"not much more according to the MSDS sheets and Wolfgang Unger himself. his process uses up to 35% post consumer recycled FRP (old boat hulls). I mixed up my own resin/bondo and tested the material properties along with the seacast back when I did my Avanti. performed a cantilevered load test as I was at home didnt have a charpy notch test rig. I used weights to add load until failure in bending, and the results were similar (within a few %). when the samples broke, the substrate separated on the gel-coat side of the hull chips."
sphelps
I don't know where the Bondo thing is coming from because we all know the main ingredient in Seacast is smurf berries ....
kcassells
Yea so let's make one. Typically the costs of a product are less than a 1/3 of the sales price.. The rest of the costs are attributed to development,patents, liabilities, marketing, shipping and mfg of bulk inventory to lessen the costs. Whereas then you have the other related costs of, inventory, labor, warehousing and distribution.
All the listed above compliments mean absolutely nothing unless marketing/sales moves the product.
If a "garage" recipe can be created then yahoo! And good bye Seacast.
Of course in the above scenario typically there are "investors" who simply end up making you an employee/owner and end up owning 51% + of your idea/patent, the company and profits.
But... I bet your right and it could be made in a home based garage environment.
Archbuilder who/what are you :blah: About? Not sure where your coming from. :tan:
hadaveha
They should just sale that 2 part foam allready saturated with water and just skip that step
jbcurt00
Again, the foam isnt the problem.
I dont leave the windows open on my car/truck in the snow and rain, do you?
hadaveha
No but my car is not a boat, I understand taking care of your boat, all I'm saying is that if you take good enough care of your boat why bother with epoxy on your ply wood, if it's not going to ever get rain on it or get wet bare wood would be fine
jbcurt00
If you don't understand the difference between:
I understand taking care of your boat, all I'm saying is that if you take good enough care of your boat why bother with epoxy on your ply wood, if it's not going to ever get rain on it or get wet, bare wood would be fine
and
how and why boats become waterlogged, how and why flotation foam begins to become waterlogged and what that does to the boat below decks
Then no, I don't guess you should bother
I apologize to JA that this has taken a turn to a waterlogged flotation foam discussion. I hope the earlier discussion was helpful.
hadaveha
I agree that's a argument that could go on forever but I must say I love the idea of atleast experimenting with a DIY sea cast like jig said sea cast transom with the high end treated marine ply what a set up
jigngrub
You should build your Crestliner with bare wood and no foam.
How many 1 yr. old boats do you see with wet foam? 2 yr. old? 3 yr.old? 4 yr. old?... you don't, it takes a long time for foam to saturate and it has to be neglected and constantly exposed for that long time. The only time you see wet foam is when someone opens up one of these old rotten pos boats that have been sitting outside exposed to the elements for years... and then it's "Oh my God! Look what this foam did to my boat!!!". Absolutely brilliant.:facepalm:
hadaveha
Once again jig u spoke before u comprehended what I was saying all I was saying is we all talk about spending hundreds of dollars water proofing our decks, and then use something that is known to hold water under it, your answer is don't let the foam get wet, and I agree, but yet we water proof the heck out of everything expecting it to be wet, I've got as much right to my opinion as anyone does, you fill yours with 2 part foam I'll fill mine with sheet foam I'm sure we'll both be fine. Can I borrow the big rivet gun by the way
