Anyway to ID the lift Cyl. on my engine.
Jimmy70
I have a manual pump system for the engine lift but the rubber bushings are shot and need replaced, so is there anyway to ID these units so that I can get the proper bushings for replacement???
It is a 1977 Mercury inline 6 115hp engine and looks like the engine came with the units installed and has a S-P500 manual hyd. pump which works okay. So if anyone has some ideas please post.
Thanks
Jimmy70
http://
Re: Anyway to ID the lift Cyl. on my engine.
Jimmy, I never saw anything like that setup. I have seen the PTT and the manual tilt systems. Is yours an OEM setup, or some aftermarket add on?
