aq 211a with 290-a drive trim cylinder problems
jfalco
had a great boating season with no break downs until i pulled boat out of the water , wife backed trailer in the water and i pulled boat onto trailer while my son cranked the winch in, the safety chain was hooked and i put my arms in the air and yelled its official, no breakdowns at all this year, then i went to lift the outdrive and i saw the oil slick in the water, i wanted to cry for saying that, well the hydrolic lift cylinder broke beyond a reseal kit, there is a hole on the side of the lift cylinder, im sure the other side is ready to fail also, where do i find new lift cylinders or is there a retrofit part that takes its place, i cant find them anywhere, i believe the part # is 852755, can someone steer me in the right direction.
jfalco
Re: aq 211a with 290-a drive trim cylinder problems
why are there 2 #47? which one do i need?
Ayuh,.... Because ya need 2 of 'em, port, 'n starboard sides,...
Their Twins, so the same part number,...
captmello
872612 is the part number you need, X2. pm sent.
jfalco
thanks for that pm captmello,
billbayliner
I may have some cylinder housings (not complete units) for you if you have the original cylinders with the square caps and not the replacement style round black cylinders.
Shoot me a PM with email address and I will try and get a hold of you next time I log in.
