AQ275 help needed..
mopower440
Hello, I have a 1986 bayliner with the AQ275 drive. I am trying to remove the helmet pin. Does anyone know what size bolts i need for the 'jacking bolts' to get the pin out? The pin has 2 allen bolts that come out, then i have 2 threaded holes where jacking bolts go to push the pin out.
Thanks
tighten each one 1/2 turn at a time when they bottom out to walk the pin out
