Auto thermostat ok for AQ131A?
film842
I've located an automotive thermostat that would appear to fit my AQ131A. It's rated at 82 degrees which, according to the manual is correct.
Anyone know if it's OK to use? Thanks.
captmello
Re: Auto thermostat ok for AQ131A?
As long as the temp is the same, and the thermostat fits properly, you should be good to go.
