Automatic bilge pump not priming
ruggles
Hi everyone, getting the boat ready for this season and I want to deal with this pump. I bought the boat last year and I had to deal with more important mechanical issues. So here's the deal. When the bilge fills up with rain water even if the pump is permanently submerged, it buzzes but it doesn't pump. It's cavitating. As soon as I loosed off the out take hose from the pump it starts pumping and I can then put the hose back on and it pumps it all out... Is it because there is a loop in the outtake hose causing an airlock?
Thanks
Sounds like you need a new pump. What does the impeller look like?
How high is the exit from the bottom of the pump?
Agree with wrench and will ask does the hose have a loop in it
Thalasso
The discharge hose should go with a gradual upward incline raising above the thru-hull fitting then dropping back down to the thru-hull fitting.
Do not allow the hose to dip or drop anywhere along the hose run, this can cause an air lock.
ruggles
Thanks for the info guys. It definitely has a loop in the hose and then goes up to the thru hull. I'll reroute it and test it. I can't get to the boat for 3 weeks so I'll report back then. I have to replace my blower as well. What's the quietest 3" blower for the buck?
Thalasso
The loop should be above the thru hull. This puts it above the static water line
wrench 3
It would be wise to go with a blower that's water resistant. I've replaced them on a three year old boat that were seized because the manufacturer used regular ones.
