bad reeds possibley
force91
i have a 91 force 120 that was running good then all of a sudden wouldn't rev past 2000. i was thinking possibly reed valves i noticed fuel dripping from the carbs at low rpms. im stumped not to familiar with outboard. could bad reeds cause it not to rev?? and help is appreciated
JB
Re: bad reeds possibley
Reed valves usually work fine or chip or break. If a reed has chipped or broken there will be a spray of fuel/air out of that carb.
Your problem sounds like float or inlet needle troubles.
force91
Yea I do have fuel dripping out the carbs. Is it possible for reeds do make it not rev? It also coughs at idle and drips fuel out of carbs. Replaced CDI and a coil new plugs new diaphragm in fuel pump fuel water separator and in line filter. Just wanna know if it could be a possibility. Thanks for the reply apretiate it.
You were given good advice in your other thread.
You can follow it and diagnose/troubleshoot the problem(s), or you can keep guessing and throw money at it.
You need to check compression, spark, and throttle operation. Probably need to rebuild carbs and do a link n sync. and check the timing.
You going to need a service manual to get through it.
force91
Think I figured it out the CDI module was toast I noticed cylinder 1,2 had weaker spark than 3,4 I had a extra box laying around and she fired right up gonna try it in te water today reved really good better that before hopfully I got it. And compression was 150 on all 4. What's normal?
150 is excellent compression, near factory new.
