bait tank pump
xltier
anyone have knowledge of how the bait tank pump works. does it pump out and in or does it pump in and gravity drain out.i cant seem to find the pump because its not doing anything. my last boat just gravity drained. its a 1999 trophy 2352.
Hard to say. Depends on if the deck is above or below the water line?
Trophy is famous for draining everything in the bilge then using the bilge pump to dump it overboard.
The my fish and bait wells are above the water line. Pump feed, but drain and over flow function are gravity functions routed directly overboard with thru hulls.
cptbill
My 270 Coastal pumps water in and gravity out when it reaches the desired level
cptbill
Oh yea forgot to say it's the same pump for the wash down with a Y valve on it
xltier
I have figured it out. it has a pump for the bait well and washdown on a tee fitting. no y-valve. fish boxes empty into a box in engine bay where there is a 1000gph Johnson auto pump. drain screens were plugged up. bait well drains by pulling the standpipe out of its holder and drains overboard. I am getting there. now moving forward.
