baja hammer 22 feet with a 7.4 liter
modsrx
what size pitch that boat should run ...currently running a mirage 23 pitch and at full throttle in turn at 5400:confused: does 64 mph on gauge
Philster
Re: baja hammer 22 feet with a 7.4 liter
Well... yeah, that makes sense. A 23P prop would spin you to 64 MPH if you were over-revving that thing, as you are. Properly held to 4900 RPM, you'd max out around 61 MPH. Try not to over rev it again. Don't usually see a 23p prop on a Merc outdrive churning and burning a boat to 64.
Instinct alone says you should run a 25p, but that will knock off only about 200-250 RPM, and even that sounds too small, because you will still over-rev the engine at wide open throttle.
A 26P, 4-blade Bravo prop would be sweet on that baby. You would run into the 70's with great hole shot and midrange and bring the RPM down to a number that won't destroy your engine. Can you confirm your prop? Is it a Mirage or Mirage Plus??
Some of them Hammers are 22' LOA but even smaller if you just measure boat, so you got some grunt in a light package. I'd really like to have you give the #'s stamped on the prop and confirm it's a Mirage or Mirage Plus.
modsrx
its a mirage plus ......a friend of mind told me that boat should run in 70 mph not sure the selection of the prop ....running a bravo on that engine
Ayuh,... 1st off,... Check the Tach, against a known value Shop Tach...
Then add more pitch to get the Wot rpms down to 4800 rpms...
modsrx
tach is brand new
modsrx
thnx buddy ill look for a mirage plus or bravo will see what will come first
wca_tim
a hydromotive quadiv in the same pitch range (26 sounds right on based as mentioned above) is a GREAT prop for that sort of rig also... Tehy're also not hard to find used as folks upgrade and go to higher pitches when adding more power.
modsrx
who sell the plug that goes into the 3 air hole in the prop ??
