BAR 🍸 OPEN
IslandExplorer
Hey all, I'm building my mini bar in the old Starcraft cabin cruiser and wanted to start a thread showing various in-boat bar setups/layouts. Please post away, looking for last minute cool ideas to possibly include.. Cheers!
IslandExplorer
Here's one to get it started. 🍻
Working with a small area, 25W x 14L. This is what I have built so far but want to add glass storage and other items.
IslandExplorer
Wall mount faucet, will give more cou terspace and im not a fan of glass on a boat.
Wall mount faucet is a good idea but there's a hole already cut out so it's too late for me 😅
I also def don't prefer broken glass but I can't really sip a fine bourbon anchored at sunset out of a plastic cup in good conscience either so I think I am stuck with at least -some- glassware. Have a set of 6 rocks glasses I intend to have integrated somehow. Rest of drinkware will probably be plastic.
That's another thing I was hoping to see- clever ways to store glasses and shakers and whatnot that are rattle free but also convenient (not wrapped up in old socks or something lol) to grab.
IslandExplorer
New light, mat, and rocks glasses. Trying to figure out how to store glasses beneath in a secure yet convenient way. Thinking felt lined drawer type setup maybe...🤔20250911_230915.jpg
Grub54891
I built this table from that same flooring. I added the mahogany to the edges to hide the plywood veneer. It also has a sister table slid under it. Six coats of varnish sanded between each coat, then final coat is a rattle can of Matt Finnish to make it rather smooth.
Ah did not realize you had already started, thought that was a stock picture.
I can understand the desire for glass so if you make a holder for them with wood base the foam with hole the size of the glass cut tight and then a layer of wood with holes cut slightly larger they will jam into the foam and be se ure in heavy seas, not rattle and if you build right no one will know. I may not know much about boats but I sure know a bunch about drinking...
Buy this foam
Grub54891
Buy this foam
Good idea, also you could get that spray on felt stuff to line the upper holes to cushion the glass a bit to?
IslandExplorer
Nice, I like that table, looks like we're both repurposers. I call that veneered plywood stuff 'yacht wood'. Real handy for structural pieces and love the classic nautical finish. Was planning on bordering the little bartop with some teak or mahogany like you did too. Raised edges except where the sink area is would help with the many unexpected wakes.
IslandExplorer
Buy this foam
Whether it is drinking or not- talent shines! 😆 That really is a great idea with the foam. I happen to have a bunch of felt from another project so could certainly add some or spray it like Grub said.. This all seems very doable.
There are break proof glasses made of glass.....they are very thick and heavy. Our local glass maker ( Libbyy Glass) in Toledo Ohio has them. Small, about drink size, might be what you need. Very thick and robust, some years back, they advertised them by driving a car over them. I am sure they could break at some point, but dropping one on the floor would not break it !
