Bass Boat Latch Key Matching
DFord143
Question for all the Bass Boat restoration folks. Where are you getting the perko latches in bulk that'll all use the same key? I would like to replace the latches in my Tracker however I can't seem to find a bulk pack of latches that lock and I'd really like them to all match. I don't want four different keys for four different boxes if I can avoid it.
GA_Boater
Tracker or a Tracker dealer may sell you original type with matching keys. Wouldn't hurt to ask them.
DFord143
Funny you mention that... I actually stopped into my local dealer and the guy next to me giggled and said 'hope your ready for sticker shock' as I asked the parts guy. The parts guy rattle off what basically was nearly $85 bucks a latch with no guarantee they will be keyed the same and I politely declined them ordering them in. The parts then told me all they do is basically buy them from Amazon, mark them up and sell them to me.
GA_Boater
It did hurt to ask. :facepalm:
Perko sells to boat makers. Maybe try contacting them. I hesitate to say it can't hurt. LOL
DFord143
I've found on Amazon and eBay both lots of suitable latches that'll fit the 2" hole already in the lids. I was just hoping that someone had a good source for keyed alike bulk packs. You make a good point however... they're all made by Perko, so go to the source!
s.hadley81
Call a locksmith and Maybe they can key them alike before you install them or maybe you can buy them direct from the manufacturer keyed alike. Worth a shot!
Yep contact Perko themselves for a quote and if that doesn't work then a good locksmith can easily make the changes. I am luck to have a good friend that is a locksmith and he has even keyed padlocks for me so it is very possible if you can find someone at a reasonable cost.
Silvertip
Those locks are the simplest on the planet. Remove them and have any reputable locksmith key them all the same.
