Bass boat refinsh.
N Wolf
I know from building model boats that epoxy will stick to polyester. I am going to try tip and roll with some west system epoxy for a clear. If anyone has tried and failed, let me know.
Re: Bass boat refinsh.
Ayuh,.... I've done tabletops, but they don't sit out in the Sun,....... Epoxy is not UV protected....
yupper! before you waste the $$ you might want to check with west. i have heard the same...not uv protected and it simply won't last.
Woodonglass
Why would you not try to roll n' tip regular Clear Coat???
