Bass Tracker Aluminum boat leaking?
xxlurchxx
Well I finished redoing the bass tracker and took it out for the first time. Remembered to put the plug in and pulled out into lake. Within an hour had water coming throught the floor boards. Pulled it out of the lake and emptied it. Put plug back in and ran water under the deck. The only place water came out was the outlet holes for the live wells? Should you plug these? HAve not hooked up bilge and electrical yet could the lack of power to the wells allow water in?
WIMUSKY
Say cowboy, this Topic is 4 years old. It would be best to start your own Topic for the best results... The OP hasn't been active for 2 years.....
Thanks,
WIMUSKY
