Batteries for bass tracker
fishin0001
Hello, I have a 96' 40 hp basstracker, 2 fishfinders,stereo,lights and a trolling motor question is I have a deep cycle battery and a cranking battery. I have the trolling motor on my deep cycle and everything else on my cranking battery is this the proper set up?
thanks
You might want to invest in a battery switch. Take advantage of the outboard recharging the battery and being able to draw power from bot batteries when needed - such as starting. A lot really depends on use. The 2 fishfinders are probably on all the time but not as much as the stereo or lights. And yes you sound like you have a proper set-up ;)
