battery isolator question.
nrob84
ok first off thank you for all your help you have provided me in the past. ok so here we go, i have a 87 wellcraft cuddy, witha merc 470 4 cyl. it has the larger heat exchanger, and an alt. conversion kit installed, it has a 100 amp one wire alt installed, an SE106 outdrive, and i replaced the 2 junk batteries with 2 marine deep cycle batteries. i use the boat mostly for running around the bay and out to block island and fishing, mostly fishing, i like to listen to the radio and vhf while im stopped, i do have a dual batt switch installed but its kinda a pain to keep switching it for starting, runing and stopped, using the radio, (its not in the greatest spot) sooo i want an isolator. i looked around on these forums but couldnt find what i was looking for, first is there an isolator that i can turn all power off for when its home on the trailer? and second i read something that said it is bad to charge 2 batteries off one alternator because it could damage the alt or the batt, is this true? i think he may have been talking about an outboard motor. and can anybody explain how to wire it so i always have one battery for starting, and when the boat is off everything will run off the other batt yet both will charge when the engine is running... ive thought about this to much now my brain is mush, gotta go grab a beer, that will help!! again thanx for helping!!! you guys are the best...
JustJason
Re: battery isolator question.
Yes it's true, unless you use an isolator. That's the isolators purpose, to isolate 1 battery from the other so the alternator can charge both batterys without over or undercharging each battery. It all keeps a dead battery from draining down a good battery.
That being said, you really should use 2 starting batteries, or at least 1 starting for the engine and 1 combination battery for the house. Alternators will charge deep cycles, but it doesn't charge them correctly, and the batteries are going to wear out in short order (a season or 2, vs the 5+ years it should last)
You can still wire in a battery switch in between the engine and the isolator. All you would need is an ON/OFF batt switch. If you already own a 1/2/ALL/OFF switch you can still use it, you just won't wire anything to #2
An alternator can charge any type of battery you put on there. The only difference between a start battery and a deep discharge battery is the thickness of the plates. I would suggest making both batteries the same type for example both being AGM or both being a wet lead acid. for my boat with a 7.4L engine, I use the marine deep discharge batteries that Costco sells. My batteries last 5 years. The biggest enemy of batteries is not keeping them fully charged or discharging them to deeply. Even deep discharge batteries should not be discharge much more than half of their capacity.
I prefer using a ACR(automatic charging relay) which combines the batteries when either battery voltage gets above a set voltage(means the alternator is charging).
Look into getting this. Has the switch and the ACR.
http://bluesea.com/category/2/productline/overview/329
Silvertip
Iis amazing how much mis-information there is about this. Look at it this way. What is a battery? It is a "battery of cells" or a "group of cells" connected in series to make whatever voltage you wish. Diesel cars and trucks have had multiple batteries for years and they are charged from a single alternator. I recently helped a stranded trucker whose truck had six batteries, all in parallel. So this business of not charging multiple batteries is an old wives tale. Voltage regulators monitor "system voltage" and could care less how many batteries are attached. They will all be charged since weaker batteries in very short order suck from the stronger battery(ies) so equalize the "system" When the system equalizes, they all get an even charge until the regulator says "done" and goes into maintenance mode. If one attached two very large capacity batteries to an outboard whose output is 10 amps or so, is that would cause the alternator to be working at near capacity 100% of the time. Things get warm and the regulator, rectifier or stator may go south. But this dude has a 100 amp alternator which is easily capable of handling 3 or four batteries.
nrob84
oops i think i started an argument... ok so hold on one sec, is it ok that i bought 2 deep cycle batteries, (the boat only has 2) i have a switch that has 1 - 2 - all - off, i usually start with batt 1, then while its running switch to all, then when i stop and listen to music i switch to 2. pain in the ***** when i move spots every 15 to 20 mins, should i buy a different type of batt for starting? if so why? i got a deal on the deep cycles from autozone so i got them they are 650 cranking amps, deep cycle, with a 3 year free replacement. maybe i shoud buy a third batt, just a cranking? and leave the 2 for lights and radio etc.?? damn im confused now, what he was saying about the system voltage seems right, i went back and read what the other post said, it was for an outboard 70 hp, so he over heated his charging system, i have a 100 amp with a 4 guage wire from the alt to the batt switch, shouldnt overheat... i hope. hmmm sometimes the engine does crank slow but does start, do i have the wrong batt for starting?
Your deep cycles are fine. I use mine to start a 7.4L engine. Will be more than adequate for your 4 banger.
nrob84
ok... soo ill stick with the deep cycles. sooo i was looking at the isolators iboats sells. under features it says, "E terminal for e" what does that mean? is it a typo? and wait, if this doesnt allow the lower batt to equalize with the higher charged batt, wont that overcharge one batt while it charges the dead batt...???
Look at the link I posted.
Use an ACR instead of an isolator.
The E terminal on an isolator is where you would hook up a sense line.
nrob84
hmmmmm ok so you all made me think. so i did a ton of research. heres what i found, if you charge 2 batteries off one alt. as long as the alt. has a high enough out put both batteries will equal out and you will not overcharge eithor battery because the batteries are wired together and even out, think of it this way take 2 fifty gallon barrels put a pipe between the 2 at the bottom and start filling one with water, they will always be equal battery voltages work the same way... you may have a problem if you have a low output alt because when the batteries are low you will force your alternator to run at 100% output for a long time and it may overheat.
so with a isolator installed it basically has 2 diodes that allow electricity to flow into the batteries but not out of them. effectively seperating the 2 batteries. so one battery is wired to the starter and to one terminal on the isolator, the other batt is wired to the second terminal on the isolator and to the fuse panel that runs everything in your boat. (so the 2 batteries are NOT connected to eachother at all) and the alternator is connected to the third terminal. so now the tricky part, when the alt starts charging electricity flows to the lowest charged batt first because charging current flows preferentially into the battery with the lowest charge (because of the higher potential difference). then when both batteries have the exact same level of charge it flows to both batteries till they are fully charged. these things are way less complicated then i thought they were. i hope this helps someone out there someday.
nrob84
bruce your the man!! thanks!! thank you to all of you for your input!!!!! i love this forum! time to find the debit card...
JustJason
Alright since i've already thrown in my 2c, and because I love to argue with Bruce :) I'll add some more just for your consideration, because after all, this is your choice here.
Keep this in mind to, there are 3 ways to do everything, your way,
my way, and the correct way.
That statement is not 100% accurate and here is why. In a perfect world, the alternator doesn't care.
The alternator doesn't care if you hook up 100 batterys to it in series or parrallel as long as the net result is still 12VDC. Silvertip is correct, the alternator will charge them all, albeit a bit slower. But unfortunately nothing in life is a perfect world.
Frog water isn't so bad to boat in. Sure you get corrosion and all that, but it doesn't happen overnight. The salty drink is a different story though. Epecially if your moored or docked and jacked in to the shore power with 100+ other boats.
Here is your new best friend, and worst enemy, so you best get to know him.... Corrosion.
Like I said (and silvertip) you can have 100 batterys all hooked up to 1 alternator, no problem.
But when you add corrosion you add voltage drops across a line, it is a problem inherent with DC electricity. (which is BTW, why we have AC electricity in our homes) If Edison had his way we would all be on DC. But if we all had DC there would be electrical substations every couple of miles compesating for the voltage drops. That and AC is cheaper to make on a grand scale and high voltage AC is somewhat safer than high voltage DC. Now bow your head and say thank you Tesla.
Anyways... if you have 2 batteries in parallel you will have at a minimum of 5 to 6 cables of heavy gauge. If you use a battery switch you will have even more cables. But if over time because of corrosion (and it will happen) you have a .5VDC drop in 1 cable, and a .3VDC drop in another, and a 1.1VDC drop in another etc etc... the batteries will not charge correctly. The batteries with little to no voltage drops in its cable will charge properly, but the other batteries with multiple drops in its line will not charge. The voltage drop eats up all the current that is supposed to go to the battery. No big deal if you have 1 battery that's good to go while your boating, but when you shut her off and let her sit for a week. The high battery will slowly drain into the low until they equalize. But here is the kicker, the alternator sees a group of batteries as 1 load. Wether it's 1 battery, 2 batts, 200 batts, it's still 1 load to the alternator. But if you have exxecive voltage drops in the entire battery system, the alternator will overcharge the high batteries if the overal voltage appears low in the system because of the drops. It's that what the alternator thinks 1 particular battery voltage is that controlls the charge rate, it's the overall voltage of the system.
So if you had 2 batteries.. 1 that was 12.7 volts and fully charged, and the other that was sitting not so pretty like the ugly gal in the corner at prom at 9.5 volts because the line drops ate the current. After a week you have a 1 battery system that are sitting at 11.1 volts. 11.1 isn't awefull, if the batteries have some current still in them. It will still crank a motor..... but slowly. Slow cranking RPMS is the #1 reason for hard starting, period.
On top of that, if your motor is EFI, or something else that relies on electronics as part of it's operation. (for example, A yamaha YMIS microputer, J/Rude optical eyes on their older carbed but electronic ignition motors) the engine will not start. Most electronics have a minimum voltage requirement. Drop below the min, and it doesn't function any more. So you can crank until the batterys are dead and the starter is smoking, but the electronic parts of what the motor needs to run will simply not even turn on.
So in the end... To isolate or not. Sure it costs money, but here is the benefit.
1. 1 battery will not drain into the other.
2. If you have voltage drops, (and you will given enough time), the high battery will not be overcharged, and the low battery will still charge somewhat, but still somewhat better than if it was just parallel'd.
3. It's sortof better if your mixing starting with deep cycle batteries, and i'll touch on that more in the next paragraph.
Now... onto starting vs deep cycle vs combination batteries.
Didn't I say I loved to argue with you???? :)
Well I won't argue, but I don't agree with that statement.
True, very true, as long as the system as a whole is 12 volts. But it comes down to charging rates, and how much the battery likes being charged at a certain rate.
You have...
1. Load/Bulk charging, which is what an alternator does.
2. Absoprtion/high trickle charging, which is found in a home battery charger.
3. Float/trickle/maintence charging, which also is found in battery chargers, but the chargers that are specifically designed for deep cycle batteries do a better job of it.
starting battery
Charging type
1. Bulk I dig it, I give up juice fast and i like juice fast, makes me strong like arnold
2. Absorption It's not a big deal, but can you get on with it man, I dont have all day
3. Float Okay serious, this is like trying to get fat on lettuce, throw me a bone here
deep cycle
Charging type
1. Bulk Whoah, this is like current overload man, I don't like it, I'm gonna make some heat
2. Absorption Okay, I like to slow dance, but i like to realllllllly slow dance, wink wink
3. Float Now your singing my song baby, don't stop
In a perfect world you would have 2 alternator options, 1 for starting, 1 for charging. Look at battery chargers. In el cheapo charger you get a 30-50 amp absorption charge option only. In a good high quality battery charger you get options like
1. Multivoltage
2. Starting/deep cycle/maintence selector switches. (Bulk, absorption, or float charging rates)
3. battery start
4. quality components, no AC to the battery while charging.
5. Automatic modes
6. Gel and AGM modes (effects charging rates).
If your building things on the cheap, there is no 1 charger to charge all types of batteries.
Alternators are a once size fits 90% of our battery charging needs solution. And cheap...(okay... not a Mando)
Deep cycles will charge off an alternator, is it the best for the battery? No. Is it the best for the alternator... it doesn't care, it has 1 charging rate. The alternator is either on or off depending on the sensed voltage. If it's on, most alternators will give you 50-75% of their total rated amperage output until the voltage on the sense wire raises.
Ever go to a fishing tourny. At night all the boats are parked at a hotel. All the competetors have extension cords thrown out their windows plugging in their batterys. These guys are serious boaters with serious engines. The new Optimax's, the New 4 strokes, all have conventional high output alternators on them, but they still charge their trolling deep cycle batteries with a high quality deep cycle charger. Those guys know how to squeeze every Ah out of their batt's.
Now on to the last of my tirade... Using a deep cycle as a starting battery.
Can you do it... sure.
Is it ideal.... Nope.
Deep cycles are rated in amp hours, not cranking amps.
Starting batts are rated in cranking amps, with amp hours being a secondary rating.
So when starting an engine, you need a minimum amount of amps, and ideally your way over the minimum with power on tap, how do you even rate a deeps cycles cranking amps?
Some companies that make deep cycles will throw a number on there to sell more batteries. Reputable companies will not.
If you plan on using a deep cycle for a starting, buy the biggest battery you can fit, not afford but physically fit, or else you'll have issues. If you use any deep cycle battery you are likely to have slow cranking rpms, even with a big one.
That is not true. The difference between a marine battery and an automotive one is in the thickness and overall durability of the battery to abuse. The difference between the 2 is surface area.
If you took 2 batteries that had the same external dimensions and cut them open what you would find is that a deep cycle has little surface area on it's plates, but a starting battery has more surface area by corrugating its plates or having the lead have a spongy like surface.
Every battery has 2 different typs of plates, an anode and a cathode. A cathode gives up free electrons that want to travel to an anode. A starting battery has a bigger cathode plate in surface area for the batteries specific external size than its deep cycle counterpart does. More surface area means more electrons. More free electrons means more on demand (starting) power.
A starting battery has tons of electrons to give you when you need on demand current for short periods of time. A deep cycle still has those electrons, but because of reduced surface area of the cathode, it can not give up those electrons as quickly as a starting battery.
Anyways, i'm done typing to this thread tonight, I may add to it in the future if i'm up to it.
nrob84
oh boy!!!! damn justjason just killed it... haha. are you a batt. expert?? i now know way more then i ever thought i would about batteries!! ok soooo here is my plan after reading his post. new batt cables, (no idea how old mine are!!!) a high cca starting batt, a on off switch and an isolator. and since i have an extra deep cycle. ill trickle charge it and stuff it under the seat incase i ever somehow kill my start batt. damn, justjason i owe you a few beers, ever find yourself around RI near the bay let me know!!! ok well im off to bed its late! and my brain hurts now. i told you i love this place.
Jason loves to type! Jason, you shouldn't be drinking when you post these!
The reason a start battery has thinner plates than a deep cycle battery is just as he says...because there is more surface area so that there is more metal exposed to create the chemical reaction to deliver more current when you start. On the other hand, when you are charging, it makes no difference because we are charging at a relatively low current.
An alternator is not on or off as Jason says it is. It tapers the current as the battery or batteries charge. All it cares about is the voltage it sees. It just delivers enough current to make sure that the voltage is where the regulator wants it. As the battery fully charges, the current necessary to keep the voltage at the necessary level drops until very little current is necessary.
The reason all the fishermen have their boats plugged in at night is because they want their deep discharge batteries charged fully. They can't rely on the low output of the outboard motor's charging system to be able to fully charge them during the day for the low number of hours they are running the motor.
As far as all the other stuff that Jason wrote down, I don't even have the time and energy.
Rob, put the ACR between the two batteries...any two batteries!
JustJason
Nahh... i only drink on the weekends, sadly its only thursday :(
Bearfeather
I just recently dealt with a similar situation and solved it with a relay that switches automatically when the alternator is charging. Much easier than the old isolators took me about 10 minutes cost $80. No need to disconnect or reroute your alternator simple junction wire between the starting battery and your accessories battery. The wire only has to be large enough to handle your alternator output so just buy wire the same size as what connects to your alternator no need for battery cable size wire. I now have these on both my boats and they do an excellent job of keeping all the batteries charged but most of all they keep the starter battery isolated so it doesn't get discharged and I don't have to remember to turn a switch!!!
