battery moves
6 balls
I have a 05 Bayliner 185 i got if out of mothballs yesturday and charged up the battery and put the cover of the case back on but noticed that the battery slides about 4-8 inches in all directions like it is not bolted down i never noticed this before? is this normal or is it supposed to be bolted down like a car battery?
Belchy
Re: battery moves
Any boat battery must be bolted down to avoid being thrown around in rough water. Battery not tied down can do a lot of damage.<br /><br />Belchy
vipzach
Re: battery moves
It sounds like your battery box is alot bigger than your battery. You could put some tie downs inside the box, look at the link, there are some towards the bottom of the page. I have also seen some at auto parts store that you can screw down little brackets on both sides of the battery and do the same thing that is in this link battery tie down (here at iboats) or you could get a bigger battery to fill the box. :D
jtexas
Re: battery moves
2nd season with the new boat, eh? Your dealer either undersized your battery or oversized your box - sounds like a customer service failure to me. <br /><br />yah, don't let it slide around - shim it with some 2x4 scraps until you get around to the permanent solution. it'll take a beating on the trailer and on the water - shorten its life.<br /><br />BTW that battery will live a longer life if you keep it charged in the off-season.
6 balls
Re: battery moves
thanks for the replys the battery fits real snug in the box its the box that slides around i have the strap on as tight as i can get it but the whole box moves around it can only move within the 8 inch area then it seems to hit a stopper or something i have looked but dont see a way to bolt it down am i missing something :confused:
CN Spots
Re: battery moves
Mine is screwed to the deck, well, sub-deck. But it's aluminum.
studlymandingo
Re: battery moves
Take the battery out of the box, see if the box moves about freely. If so, look around for the method by which the battery box is fastened to the boat. Sounds like something has come undone, which is not uncommon for a boat!
Re: battery moves
You Should have a couple of brackets screwed to the floor, that the battery Strap is fed thru to hold Everything down,+ secure....<br /><br />These aren't the best pictures,... But, you can see the little retaining brackets.......<br />
<br />Here's a Much Better shot.........<br />
<br /><br />I'd say your brackets either pulled out, or aren't hooked over the strap......
