Battery size for fishfinder
Installing a Garmin Striker 4 fishfinder, what is the minimum size battery needed. No other equipment will be wired to this battery. TIA
FunInDuhSun
I had a portable FF that ran off 8- D cell flashlight batteries. It typically lasted for the entire summer.
FWIW, on my tinny I use a lawn tractor battery. It not only runs the sounder, horn, and running lights, but also starts the 25HP outboard.
matt167
Motorcycle battery could be enough. A lawn tractor battery is cheaper however
Alumarine
I've also run them on CPS5.5-12 and SH1228W UPS batteries that I've had lying around.
