Battery Switch for a Yamaha
I'm looking to install an on/off type battery switch on my starting battery. Motor is a 2015 Yamaha FL50 . Any recommendations? Blue Sea looks like they make a good switch but I'm not sure which size matches my motor.
89retta
Why cant you turn it to off with the engine running ?
Lightwin 3
If the engine is charging, the voltage has no place to go, Thus, it goes to the weakest point-usually the regulator.
With no load, the alternator output can go to a very high voltage which can wipe out the regulator and diodes.
I only use BlueSea switches these days.
