Battery Switches & Setups Demistified
Status
Not open for further replies.
PondTunes
There are many different configurations of engines, number of batteries, and how they are hooked up. This guide should help explain how switch setups are connected to banks of batteries & the charging systems that keep them powered.
Points to keep in mind:
1) NEVER Ever switch a On/Off disconnect or OFF-1-2-BOTH switch to the OFF position with the engine running or you will end up with a dead charging system. Alternators do not like being disconnected while running. If you are going to be switching them at all while the engine is running (ie 1-2-both) be 100% sure that they are make-before-break design!
2) Always use a meter / circuit tester to verify circuits a short circuit or reverse polarity can be just as rough on your charging system as disconnecting it while running.
3) A repair manual for your engine is a great, inexpensive investment that will tell you what every wire, nut and bolt are for that is connected to your engine.
SINGLE OUTBOARD ENGINE CHARGING SETUP:
This is normally a very simple setup consisting of ONE engine and ONE battery. Outboard engine alternators normally do not have the output of marine inboard engines and the output should be checked before considering adding batteries to the system. Keep in mind these systems are designed to keep your batteries topped of and NOT to recharge dead batteries..
That being said you should take into account the average current draw per hour of your accessories to see if your engine is even capable of supporting your loads. Say for example If you run a trolling motor, depth finder, bilge & lights and lets just say that that works out to 15 amps off of your battery. A small outboard may have a 10 amp charging system (meaning it can put 10 amps back into a battery per hour) Thus it would take 1.5 hours at WOT to fully replace what you used. Charging systems on outboards vary a lot with 35 amp systems being available on newer, larger outboards so it is important to find out exactly what you are dealing with. Keep in mind if you happen to pick up a big group 27 battery with say 90 amp/hour reserve it would take even the 35 amp system about 2 1/2 hours at WOT to recharge it from a discharged state!!!
An alternative to using a dual battery setup on an outboard powered boat one could consider having a large deep cycle battery connected to the high draw loads such as stereo amplifiers or trolling motors. These items would be completely isolated from the starting system/circuits and would be the only things connected to the spare battery. Our big group 27 battery with 90 amp/hour reserve would last for about 6 hours if we maintained a 15 amp draw on it! These accessory batteries would be charged using a maintainer or shore charger each time the boat is brought in or brought home. They could also be used in a pinch if the main battery were to fail for some reason.
The backup battery:
In the above image (Fig #1) we have our outboard engine, battery #1 & battery #2 and a OFF-1-2-BOTH Switch (A). Note post (C) on Switch (A) it is known as our common, ie if the switch is set to 1 or 2 then common will be connected to 1 or 2. Our house load & engine is connected to the common post (C) on switch (A). Lets say battery #1 is a normal marine cranking battery and battery #2 is a dual purpose starting/deep cycle. Proper operation of this system would be to use selection #1 for cranking the boat, then driving to our fishing hole. When we get to our fishing/swimming hole we shut down the engine and move switch (A) to position 2. This disconnects our main starting battery and allows us to run the trolling motor and all other house circuits off of battery #2.
If we manage to totally drain battery #2 dead we are still ok because battery #1 has plenty of charge to get us going again. Once it's time to go or move to a different spot battery #2 should be selected while the engine is running to charge it. The BOTH setting should NOT be used on an outboard to attempt to charge both batteries in my option because they just don't have enough charging power to even dent two batteries unless you have a very long ride at WOT ahead of you. In essence this setup acts like a single battery system with a spare battery in the boat just in case you run one dead.
SINGLE INBOARD ENGINE SETUP
If we change gears and look at figure #1 again except with an inboard engine with a higher output charging system we can get a bit more functionality out of our switches. Marine alternators much like car alternators normally produce much more charging power than outboards. High output upgrades are also available in as much as 100-250 amp configurations. These alternators are capable of keeping the charge up on multiple batteries. We could also use the BOTH setting while underway to top off both batteries. However; as with the outboard engine you should look at your current draw/alternator output to decide how much your charging system can handle.
There are some drawbacks to this setup however. Lets say our operator had Switch (A) in the BOTH setting to charge his batteries. It is possible that if he sat long enough he could drain BOTH batteries while fishing/swimming or whatever. There is also the possibility of if one battery happens to bad it could drain the other battery while in the BOTH setting... He has to remember to switch the switch from BOTH to a single battery while anchored. For someone who has always had this setup it probably will never happen, if you add this setup to your boat it's likely that you could forget because it's a new step you have to follow.
SINGLE INBOARD ENGINE SETUP (AUTOMATIC)
This setup involves a special switch/relay that automatically connects/disconnects the batteries to the charging system. It simply takes the remembering to switch step out of the equation and improves on an otherwise good setup.
Fig #2 - 1 Engine w ACR
What we see here in Fig #2 is that Switch (A) has been replaced with a special dual circuit switch that works much like switch (A) but has four poles. The house loads are connected to pole 1
The charging system is connected to pole 2.
Battery #1 is connected to pole 3 and is our starting battery
Battery #2 is connected to pole 4 and is our house battery
An ACR or automatic charging relay is connected to the positive post of both battery #1 and battery #2. This relay is responsible for connecting/disconnecting the batteries in parallel and prevents the house battery from discharging the cranking battery.
Once installed the dual circuit switch (D) will disconnect both batteries when in the OFF position, and connect them when in the ON setting. It also has a COMBINE setting for emergency use in case something happens to our cranking battery. In an emergency is the ONLY time the switch should be changed to combine, the ACR handles charging the house/charging batteries without us doing anything.
When we crank up and get underway the ACR closes the connection between battery #1 & #2 and allows both to charge. Once we shut down the engine the ACR detects that there is no charge present and breaks the connection between the batteries.
Two Engines Two Batteries
This setup would be the same regardless if the engines were inboard or outboard. Normally these setups will be found with two OFF-1-2-BOTH switches wired up to allow either battery or both to crank either engine. The house battery #3 is not recommended for outboard setups.
This setup gets a little more complicated to explain so please refer to figure #3 as you read along. Under normal use the Switch (A) would be set to position 1, Switch (B) would be set to position 2. Battery #1 would crank the starboard engine & supply power to the house circuits. Battery #2 would serve only to crank the Port engine. While underway no switching is required, battery #1 is charged by the starboard engine & battery #2 is charged by the port engine.
When the engines are stopped the house circuits run off of battery #1. If we were to drain battery #1 we could simply move switch (A) to position 2 and use battery #2 to crank the starboard engine. Likewise if something were to happen to battery #2 and it died we could use position 1 on switch (B) to use battery #1 to crank the port engine! (wow that was complicated)
The BOTH setting really does not have much use in this setup the switches should never be left in the both position as they could leave us with two dead batteries. BOTH could possibly be used in the event that say the alternator on the port engine failed. If so Switch (B) would be set to OFF and Switch (A) would be set to BOTH... (WARNING! Never Ever Ever set a switch to OFF with the engine running or you WILL have a failed alternator!)
With Switch (A) set to BOTH and (B) set to OFF the starboard engine would be charging both batteries and both batteries would be used to crank both engines.
Figure #3 also shows an optional house battery #3 (Not recommended for outboard engines!). A simple OFF/ON Disconnect switch (D) could be used when anchored to run the house circuits and ensure that battery #1 and battery #2 were fresh for cranking. With the switch in the ON position battery #1 and Battery #3 would supply the house circuits & be charged by the starboard engine. With switch (D) in the OFF setting only battery #3 would supply the house circuits with power.
As an alternative a ACR - Automatic Charging Relay or battery isolator could be put in place of switch (D) for automatic isolation of the house circuits.
PondTunes
Re: Battery Switches & Setups Demistified
Battery Switches & Setups Continued....
Two Engines Two Batteries One Switch
Normally not seen but by all means possible when using a Dual Circuit Switch (D) This switch does the duty of two OFF-1-2-BOTH switches and allows for the batteries to be combined for emergency starting.
Figure #4 shows the Dual Circuit Switch (D) in normal operation:
The starboard engine & house loads are connected to pole 1
The port engine is connected to pole 2
Battery #2 (port side) is connected to pole 3
Battery #1 (starboard side) is connected to pole 4
When in the ON position battery #1 is connected to the starboard engine & house loads. Battery #2 is connected to the port engine only. If the starboard battery is dead the switch can be moved to the combine setting to crank the starboard engine.
This setup could be expanded with a house battery & ACR or isolator as another option.
Terminology (Terms used in this guide and what they mean):
Series Wiring -> Method of wiring that doubles the VOLTAGE of the bank. Ie 24 volt trolling motor could be powered by two 12 volt batteries wired in series. Positive from battery #1 connected to the trolling motor, negative from battery #1 connected to Positive of Battery #2, Negative of battery #2 connected to the trolling motor ground. Result = 24 Volts
Parallel Wiring -> Method of wiring that doubles the available amperage of two connected batteries while keeping voltage the same. Ie 2 identical 12 volt batteries with 500 amps reserve would be connected positive of battery #1 to positive of battery #2 and negative of battery #1 to negative of battery #2 would result in the circuit having 12 volts with 1000 amps reserve.
Battery Bank -> One or more batteries connected together either wired in Series or Parallel..
House Loads -> Accessories such as lights, trolling motor, radio, fish finders or anything else you would be using while the engine is off for long periods of time.
OFF-1-2-Both Switch -> Type of battery selection switch that is commonly used in multiple battery switch setups. This type allows for total disconnection as well as emergency parallel connection of the batteries. (Also known as a DPST or Double Pole Single Throw Switch)
Off-On Switch -> Type of switch that either is ON or OFF normally used in single battery setups or just as a master disconnect. (Also known as a SPST or Single Pole Single Throw Switch)
Dual Circuit Plus Switch -> Type of switch that is designed to do the function of two OFF-1-2-Both switches, also allows for a parallel connection between the two batteries. (Also know as a TPDT or Triple Pole Double Throw Switch)
ACR -> Automatic Charging Relay, a smart relay that automatically connects/disconnects batteries in parallel based on drain. Can be used in conjunction with the Dual Circuit Switch for automatic charging setups.
PondTunes
One Engine Two Batteries w/ Isolator
This setup will keep battery #2 charged for a trolling motor or backup battery without the user having to do anything. In the event of a problem with battery #1 all loads can be switched to battery #2.
In the above image (Fig #5) we have our inboard engine, battery #1 & battery #2 and a OFF-1-2-BOTH Switch (A). Note post (C) on Switch (A) it is known as our common, ie if the switch is set to 1 or 2 then common will be connected to 1 or 2. Our house load & engine is connected to the common post (C) on switch (A). An isolator is present between battery #1 and Battery #2 to keep Battery #2 charged without interaction... Normal operation of this setup would be to leave the OFF-1-2-BOTH Switch (A) in position 1, position 2 could be used in case battery #1 failed or was discharged. Off could be selected to totally disconnect all loads from the batteries (NEVER WHILE THE ENGINE IS RUNNING) and BOTH would really never need to be used...
achris
More fish than mountain goat
Nice description of all the options... Would like to add one more option, which does away with having to remember to switch banks etc. I'm not as good as you will the clipart so I will just describe it....
One engine. A single battery in place as normal. Add a second battery and connect the 2 batteries together with a relay. Have a 3 position switch, with OFF, ON and momentary ON positions, on the dash. Connect the power from the ignition key to the 'ON' terminal on the switch, a hot wire from the second battery to the momentary ON terminal and the centre terminal on the switch to the coil of the relay.
How it works.
1. Switch in the centre OFF position. System runs on a single battery. Second battery not in circuit at all.
2. Switch in the ON position. Second battery isolated until ignition key is turned to ON, then both batteries are connected in parallel. Both involved in starting and both are being charged. When the key is turned off, then the relay drops, isolating the second battery. Should the primary battery become discharged and unable to start the engine,
3. Switch pressed and held in the momentary position. This pulls the relay using the power from the second battery, also allowing it to be used to start the engine. Once the engine is started the switch is released and all charging is directed to the primary battery. Or the switch is put in the ON position and option #1 is in effect.
This is the set up I have in my 4WD and I can't see a reason why it wouldn't work in a boat....
Chris.............
Boatist
I do not under stand your figure 5 with the isolator. Looks to me like there is no way to charge battery 2 unless you turn the switch to postion 2. If you turn the switch to 2 then battery 1 does not charge.
Your missing the third wire to your battery isolator. To work right the third wire needs to come from the alternator.
Chris and Pond, I came up with a configuration which I think is optimum, since it requires no operator intervention (an advantage when I am the operator). It is for a two engine, four battery system, and it used combiners.
In normal use, battery switch 1 set to position one, and battery one is only used for starting engine one. Battery switch two is set to position two and only used for starting engine two. The two house batteries are connected each to one battery via a combiner, and all but engine starting current is isolated to the house batteries. Starting battery for engine one is also connected to battery switch two position two. Starting battery two is connected to battery switch one position one. Now if one of the starting batteries goes dead, the other engine starting battery may be switched in (after starting its engine), to start the other engine, simply by flipping the battery switch. Also, the running engine will charge the other starting battery simply by flipping the switch.
achris
Chris1956,
My system can be left in the 'ON' position and that's all the operator has to do. When the key is off, then the relay drops and the second battery is isolated, when the key is on, then the second battery is in parallel with the first. The only intervention is if the first battery is flat, then you just press the switch to the momentary ON position, start the engine, flick the switch back to the ON position and carry on as if nothing had happened...
Chris...............
Achris, In your system, if the primary battery is dead, and you manually connect the second battery to the starting circuit, is the primary battery still connected to the starting circuit? If so, the good battery can discharge into the dead battery, and maybe not start the motor, if the battery is shorted or something....
Silvertip
In my veiw you cannot beat the simplicity and versatility of the standard and inexpensive OFF-1-BOTH-2 battery switch. No relays, no isolators, no buttons, and if you can't figure out what off, 1, both, 2 means or when to use those settings, then some training is necessary. That switch allows you kill everything, start with either or both, charge either or both, or run accessories from either or both. No fuss -- no bother and no other stuff to go wrong. Perhaps the switch should be labeled OFF-START-RUN-ACCESSORIES to make it as someone once said "perfectly clear".
Silvertip, While I agree with you on the simplicity, I find two problems with the tradational setup. The first that sometimes the battery switches are located near the batteries, in the bilge. On my friends "Sundancer-style" boat, this meant you had to pull up the hatch in the floor of the cockpit to change the switch settings. Not easy or convenient, since the hatch was heavy, and we always had coolers, chairs and fishing gear in the cockpit, which needed to be moved elsewhere..
This cruiser also had twin SBC and Alpha drives, four batteries and two switches. If the switches were set to both, the starting batteries could be run down by overusing the house batteries, and you would have needed to use jumper cables to start that motor, from the other starting battery, provided it had enough charge. Again not convenient. With a pair of combiners, all that manual intervention is eliminated.
Silvertip
The idea is to switch to the HOUSE batteries so you don't run down the start batteries. The BOTH positiion would typically be used in only two scenarios. 1) initial start or emergency start and 2) under way to charge both batteries. And if one needs to use BOTH to start an engine, there are other issues that need to be addressed. Other than that you use BAT 1 to start and BAT 2 as house or accessory. There is a solution to switch location problems and all it generally involves is a little thought and perhaps some longer cables. My thoughts on the location issue is to mount them parallel to the floor. A simple access hole and a knob shaped key could be inserted to turn the switches. I agree however, there is certainly more than one way to accomplish multiple battery installations.
PondTunes
The alternator is connected to the common on the OFF-1-2-BOTH switch (A) In normal operation the switch is set to position #1, this will charge battery #1... Current will flow from battery #1 through the isolator charging battery #2.
While at anchor and in position #1 battery #1 will supply cranking power & power to the house loads. The diode will prevent battery #2 from being drained, and in the event of a dead battery the switch can be moved to position #2.
This takes the simplicity of the OFF-1-2-BOTH switch and removes the need to remember to flip switches. Once it is set up you can forget about it.
No switching required under normal circumstances and a battery #2 is always ready to go as a backup.. Simple to hook up and even simpler to operate..
The idea of this setup is to be able to switch to battery #2 in the event of a failure in battery #1. Using this setup you can switch to battery #2 and disconnect battery #1 if needed. If the alternator was connected directly to the isolator on battery #1 side you couldn't disconnect battery #1 without having a live lead lying in the floor of the boat.
PondTunes
All the problems with the traditional 2 engine 2 switch setups can be solved by a disconnect switch or a isolator between the house batteries & the charging systems. See the above description of 2 engines 2 batteries. Then you don't have to remember to switch this switch to spot 1 that one to both blah blah blah, just crank up and go and forget about it.
2 engines 2 switch Diagram
Boatist
Pond Tunes
You can not charge battery 2 thru the isolator the way you state. The diode for battery 1 will block any charge from going to battery 2. You could use a voltage controlled relay or a ACR and it would work.
For the isolator to work you must have the alternator to go to the common wire on the isolator. A isolator is just two diodes hooked together. The alternator connects to the junction between the two diodes. Each diode allow current in one direction only to each battery.
It does not work like you state and if it did then battery 1 would discharge to battery 2 any time battery 2 was lower than battery 1. In the case of a trolling motor on battery 2 you would end up with two dead batteries.
SgtMaj
The topic says Battery Switches & Setups Demistified, but after reading this, I'm MORE mistified... FALSE ADVERTIZING! I'm calling the FTC! :D
So, what exactly is the point of having the Isolator?
achris
It isolates each battery (and it's load) from the other, while allowing the alternator to charge both.
Chris............
SgtMaj
Ok, but then you wouldn't want to have a switch on it, right? Because then the alternator could only charge whichever one the switch is switched to, right?
45Auto
Sounds like lots of confusion between “isolators” and an “ACR (Automatic Charging Relay)”.
Blue Sea explains it pretty well here: http://bluesea.com/viewresource/58
A quick synopsis:
Battery Isolators are made with two or more silicon diodes that act like check valves. The diodes will pass current from the charging source to the batteries, but will not pass current backward from one battery to the other or back to the charging source. Nature extracts a price for this by causing a voltage drop of about 0.7 Volts across the diodes. If you have a regulated charging source that senses its own output, the voltage at the battery will be lower than at the charger or regulator and, if not compensated for, will lead to inadequate charging.
ACR's or Automatic Charging Relays are automatic switches that close when the voltage on one of the batteries rises to a level (normally 13.2V to 13.7V) indicating the battery is connected to a charge source and is partially or fully charged. The switch then closes and shares the charging current with the other battery until the voltage drops to some lower level (normally 12.4 to 13.1 depending on model) and the switch opens. This prevents discharging both batteries when there is not enough current to charge both batteries.
With the ACR or an isolator, the batteries are effectively connected together during charging and disconnected during discharge. The isolator is the simpler of the two approaches, when used with remote sensing chargers and regulators, but without remote sensing the isolator gives poor performance.
PondTunes Figure #5 works perfectly if you replace the isolator he shows with an ACR. Then no matter which position the switch is in the opposite battery starts charging once the selected battery is fully charged.
This is from Blue Sea’s ACR page referenced above:
Pondtune’s Figure 5 with an ACR instead of an isolator is the same as the diagram above with the “center box “ simplified. The 2 position switch he shows is the same as the center box except “house” and “motor” loads are tied together, there is no way to separate them (the bottom switch on the "center box" in the pic allows them to be separated). No big deal on a smaller boat with minimal “house” loads. And if one battery craps out or is drained by the radio, etc, you just switch to the always fully charged backup to start your boat.
Silvertip
But it also means you can't charge "just" battery 1 regardless of any switch settings. If battery 1 is flat, yes you have the ability to start on battery 2 but under that scenario I want every amp of current going to battery 1 to get it back up. With this system battery 2 also is fed through the isolator thus robbing some of that output. Lose the isolator and learn how to use the versatility of the switch. It's just too simple. If it works for you that's great but the isolator is simply an extra item that's not needed. Ok - I'm outa here.
Boatist
Isolator works very well if your alternator has 20 amps or more output current.
If it is a small outboard with a 8 amp alternator then isolator may not be the best choice.
I really do not like switches as I belive they kill more alternators than any other iteam. People turn switches with the motor running without knowing what type battery switch they have. If it is make before Break and they do not go thru off then no harm. However many are not make before break and people also turn thru off and then they have to replace or rebuild the alternator.
Isolator has many advantages. One if wired correctly and someone turn the switch thru off will not harm the alternator at all because both batteries are still connected to the alternator. Two the weak battery gets more of the charge and that is a good thing if you have a decent size alternator. If the battery your switched to cable is loose or corroded and does not make connection the other battery will save the alternator from burning up. For the alternator to blow both batteries would have to come loose.
With an isolator you do not ever need to turn the switch unless you starting battery is discharged and you want to start off the aux battery.
Wired correctly your starting battery will only be use for starting and low current iteams and will last weeks even if it got no charge but it will get plenty of charge with alternator 20 amps or more.
Status
