Bayliner Capri bowrider interior restoration and reupholstery
dovydaz
Re: Bayliner Capri bowrider interior restoration and reupholstery
Managed to run out of vinyl when I literally had last few pieces to finish.. Ordered some more so should arrive within next few days! So far I have used up 20 metres of piping (this stuff just runs out before you even notice.. just ordered 4m more), 2m x 140cm of blue vinyl (ordered another metre), 2m x 140cm of grey vinyl, 10m x 140cm creme vinyl (ordered another 2m), onto my 2nd spool of marine thread (260m each).. Just so some of you who are planning on reupholstering a boat of similar size can have an idea of how much you will need :)
dovydaz
whilst the leather arrives I might try to get rid of the painted on name and possibly repaint the leg as some of the paint has started peeling off..
GB333
Hi dovydaz! You are doing an amazing job with your Bayliner!! I am also redoing the upholstery on a Bayliner Capri (1990) and I was wondering how difficult you found it to get these pieces off (see photo below). My husband thinks there is a lot of glue involved, but I don't see it. Seems like I just need to remove the screws in the backs of them. Any advice?
Here is the thread I started awhile ago - I finished all of the seat covers, but still need to do something with the side pieces. Thanks so much for your advice!!!
http://forums.iboats.com/boat-resto...yliner-capri-some-photos-question-612278.html
dovydaz
Thank you :)
Those side pieces if i remember correctly had bolts built into them so all you have to do is undo the nuts from the other side (underneath glovebox and steering wheel. There was also a screw if i remember correctly sewn in straight through the leather right on the edge (by your cupholder, if you inspect carefully you will most likely find a hole in your vinyl for the screw). For me the wood was rotten so I couldn't undo some of the bolts so I ended up cutting them off. Good luck with your project (by the way great thread! wish I saw it before I started mine!)
GB333
Thank you :)
That sounds easy enough! My husband is afraid there is a large amount of glue in there holding things together, but I don't think there is - and it sounds like from your experience there wasn't. I'm going to take those bolts out and see what happens. I desperately need to recover these pieces, so we've got to get them off somehow! Thanks so much!
dovydaz
I dont recall there being any glue, good luck with it!
dovydaz
So finally my ordered leather has arrived but still awaiting my stainless steel staples... So I ended up going to get some waterproof wood and coated it a few times with outdoor paint just to give it a little more water resistance
Tomorrow Ill start cutting out new pieces for the seats and hopefully finish off reupholstering the last part and maybe start stapling down some seats!
dovydaz
Sorry I haven't posted in a while but had been pretty busy. Recently I had the time to finally cut out all of the wooden pieces for the seats.
If any one has any particular questions feel free to ask as I won't annotate all of the images below.
All of the edges I rounded off using a router
Having disassembled the back to back seats I started to cut out all of the new pieces (if you are planing to redo the back to back seats do them one at a time so you if you do get stuck on the way you can look at the other one for guidance):
This is the back sun pad area cut out:
Seat/backrest bottoms
Starting to put back together the fold out seats:
dovydaz
Heres all the backrests complete:
Back sun pad area assembled (this took about 3 times to get it right as the bottom seat backrest part is mounted on at a slight angle)
found out that a jet ski also served very well holding the wood in place whilst it was being painted :D
Ended up making a little bit of a mess in the garden (very distorted iPhone "panorama" attempt)
dovydaz
Also made holes in the seats so the air from the cushions once applied pressure could escape (drilled them out in the original places just like on the old wood)
Today I have finished coating all of the wood so hopefully if I get some time I will start to put on the new vinyl and start stapling it all back together :)
dovydaz
Could you provide pics of how the rear seats are mounted an of the seat. I like how it can change from a seat to a sun tanning bed area. Am planning on doing something similar to mine.
Tagging along
Didn't understand what you mean previously but I have finally realised my self now as I personally didnt even know that the rear seats can make a sun pad :D
the bottom seats turn sideways one end inserts into a hole on the side and the other side rests on the engine bay cover
(this isn't my photo but I found it somewhere on the internet)
Axkiker
That sewing is impressive. Are you a seamstress or someone who sews on a regular basis. Im looking at trying a few pieces of interior but didnt know if I could pull it off or not. You are making it look easy!!!
dovydaz
No Im definitely not :) Just try it and I'm sure u will catch on to it pretty quickly! It really is pretty simple :)
looking good
GB333
Looking GREAT!!!! I got those front trim pieces off that I asked you about previously,but haven't started to recover them yet. That's all I have left to do on ours and then we put it up for sale! =)
dovydaz
Great to hear, post some photos! :)
dovydaz
Here we go! Managed to staple on some of the seats and finish off a few.
If you want any specific info just ask :)
Put on some Polyester wadding just to protect the vinyl from rubbing on the edge of the wood.
Then simply put on the vinyl and started to staple it down, set it all out so it fits well and started off by putting one or two staples in the top, and then once everything aligned started stapling all of the edges making sure the vinyl isn't loose at any sections.
dovydaz
Did the same thing with the other two bow seats
The vinyl has some bends/folds as you can see so it looks as if its a little loose but thats just from when it was folded up whilst stored so it will stretch and even out. Over all I am pretty happy how these turned out, will put them in the boat just to see how they look and fit maybe tomorrow and will post some photos.
dovydaz
Having finished the bow i moved onto the driver and passenger seats.
