bearings for yamaha 70 hp 3 cyl pressed crank
I was hoping someone on here can put me in touch with a supplier, that can supply the bearings for the Yamaha 70 hp 3 cyl which has the pressed crank. I have an engineer shop that can depress it and reassemble but want to put new bearings on it.
any help would be great
Cheers Adrian
99yam40
Re: bearings for yamaha 70 hp 3 cyl pressed crank
if they have the proper jigs and tooling to press the crank apart and back together properly
then I would think they do this all of the time and should have a supplier for the proper bearings
I believe Yamaha shop only sells the whole assembly
Cheers Adrian
All good I have found all the parts and they are all available
