Been a while since I posted,Any old friends left.
mikesea
I blew my 1994 Yammy lower and gears are OK,but wondering if ANYONE had luck welding cracks from behind prop up to the end of the carrier.? It just cracked,I found oil leaking when hauled,LUCKY I know.But thinking Id like to weld,but lookin like I need replacement.Any ideas R appreciated.I realize it a yammy,but the welding .could be anyones input.Thanks guys.$$$ are short.
JB
Re: Been a while since I posted,Any old friends left.
Hey, mike. :) Glad to see you, even if it is bad news.
Threads about Yammys still go in the Yammy Forum. I will move this for you. Good luck.
99yam40
A picture might help us see how far the crack went, but if it is past a sealing surface, then it seems like that would have to be re-machined to get a good sealing surface after wielding crack inside and out.
May not be worth the time and trouble.
Just an opinion
