beep beep beep 96 200hp efi
jbonefc3s87
My motor is constantly beeping and I have taken it to my local marine mechanic who said it was an oil injecting issue. So he replaced the oil module. Beep was still there when I took it out. He replaced the oil cap. Beeping went away for one trip now it's back. It's stopping the motor from planing. He said it's the thermostat or poppet he thinks. ???
Faztbullet
Re: beep beep beep 96 200hp efi
Stop using motor!!!!!! The only way beeping will stop motor from planing is its locking up or ignition problem!!! Since module and float has been replaced it sounds like the oil gear may have failed..or switchbox has failed on cylnider #5
Dukedog
Find a new "mechanic"...............
