Before-N-After pics
fleachili
Re: Before -N- Afer
Re: Before -N- Afer
She looks phenomenal!!
What kind of paint?
Roll or spray?
paintdude96
Re: Before -N- Afer
Re: Before -N- Afer
i sprayed it with some dupont DIC and some BAFS and clear cost call tran star
paintdude96
yellow or no yellow
yellow or no yellow
:confused:
boatnut74
Re: Before -N- Afer
Re: Before -N- Afer
Excellent job! That paint seems to have an very high gloss, that's the wonderful thing about clear coat.
JB
Re: yellow or no yellow
Yellow. :)
paultjohnson
How 'bout a strip of red on the top and bottom of the blue?
Check my signature for your answer ;)
Outback Jack
Re: Before -N- After
Looks great, nice job. Amazing what a little TLC and paint does :)What did you use and how did you apply it.
Jack
Found the answer in another post :)
Around here, we get a lot of tanic acid in the water from time to time and everything turns brown in a matter of days.
The yellow doesn't look bad new itself. Faded / stained yellow is just fugly
dlngr
yellow,and a little wider than it is now! Nice boat!!
paintdude96
thanks i was thinking more of like a Flourescent yellow like the safety yellow like and thanks again for the comment check out the before pics of it when i first got it
paintdude96
Re: Before -N- Afer
Re: Before -N- Afer
well all the white and blue is a single stage all my wood is clear coat
paintdude96
on the white it's a Dupont's Imron Industrial Strength single stage. the blue is a line of BASF call Glasurit single stage. all the wood on the inside it is a line called Transtar Finish-Tec Euro Kwik Clearcoat. i sale automotive and industrial grade paints and thanks for ur comment oh and i sprayed it all
JB
Re: Before -N- Afer
Re: Before -N- Afer
You get one thread per topic p-dude.
I will merge these two.
Mine is plain old rustoleum, fairly bright and easy to keep clean
