Belt Tension Procedure
thisuldoit
I have a 1989 4.3L V6 262 CID.
Ok, I understand the deflection test to see if the belt tension is correct, but is there a better way. What I have been doing is laying a ruler between two pullyes on the same belt, applying pressure to the belt and so long as it does not deflect more than the specifications in the manual then I am good to go. Is this correct? I have searched all over the internet and can find no good instructions on how to make sure the belt has the proper tension, so I beg for your help. :confused:
Thanks!!
Re: Belt Tension Procedure
Ayuh,........
It sounds like you've already got it Right...........
Although I personally don't bother with getting out a straightedge......
Eyeballed is Close Enough.......
Is 1 of your's Slipping,..??....
thisuldoit
1 is slipping, but it is because the tension has worked loose on it. I had both belts tensioned correctly and the respective tension pulleys tighetened down, but one has come loose. I guess i just need to retension and tighten again.
Thanks.
