bent prop shaft
jshigman1
I was in reverse when i hit something in the water and was wondering if damage was done to the gears? She shifts fine in forward and reverse and was just wondering if anything would the drive gears be ok?
Re: bent prop shaft
There's Always that Possibility.........<br /><br />All you can do, is have it Throughly Inspected, when the propshaft is Replaced.......
tommays
Re: bent prop shaft
james you posted this twice in different ways <br /><br />if you were going slow in reverse and the shaft is NOT bent then you should be ok<br /><br /><br />the real key is to check the shaft with a dial indactaor for run out to be sure its ok<br /><br />tommays
