Bent skeg pic. Bad?? Bendable?
Skyler2
Hi, shoud I try the rubber mallet with 4x4 backing or not?
Any suggestions?
I realize it is risky, but never tried it before.
This really pulls hard to the right.
72 50hp Evinrude.
Thanks, Skyler
Skyler2
Re: Bent skeg pic. Bad?? Bendable?
I'll try the pic again.
steelespike
Don't try it without heat.And you'll have to empty the gearcase to do it.If it pulls right put the trailing edge of the tab to the right.
tashasdaddy
can you try adjusting your trim tab to counter the bent skeg. if it breaks you can use a skeg guard.
Skyler2
Yes I have moved the trim tab. I'll take it out soon and see what that does.
Thanks, Skyler
Solittle
The main function of the skeg is to protect the prop. I'd leave it alone. - - - - - For what it is worth both of mine are bent (twins) and the boat does not pull.
Texasmark
The local prop shop fixes skegs also; straightens or rebuilds as required. If you have one (local prop shop) you might check with them for costs and ideas.
Mark
Joe Reeves
Should you attempt to bend that skeg back yourself, be sure to wear safety goggles/glasses. I did not one time with dreadful results.
It can be done using a big (BIG) hammer on one side of the skeg, then using a slightly smaller hammer to beat the skeg on the other side (Body Shop Scenario). Worse case.... you break it off, but any propeller repair shop can heli arc a new skeg back so that it looks like new.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
Scaaty
An old dirtbikers trick is too beat a bent aluminum lever back against a 2x4 with a rubber mallet......
harry114
Hopefully by now you have repaired this, if not use a deadblow hammer. It has a plastic face and use a steel block or big hammer on the opposite side of where you are hitting it. It will bend with no problem, start slow and you will have no problem.
Skyler2
Thanks to all for the replies. Harry, no I haven't tried to bend it yet, but I will use that mallet when I get to it. Thanks, Skyler
